Jonsey Tuna Can a Group buy, Grounding issue ? |
jim_hoyland |
Apr 27 2015, 08:25 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Has anyone installed the Jonsey billet tuna can and had a problem with the sensor ?
Mine does not appear to be cooperating... |
stugray |
Apr 27 2015, 10:41 PM
Do you mean the taco plate and the oil temp sensor?
If they chromate or anodize the "billet" (assuming aluminum) then yes you could have a grounding issue. You can check continuity from the temp sensor body to the engine case. Should be less than 10 Ohms (preferably less than 0.1 Ohms). |
jim_hoyland |
Apr 28 2015, 06:14 AM
Thanks. I'll try that .
DRPHIL914 |
Apr 28 2015, 06:45 AM
Has anyone installed the Jonsey billet tuna can and had a problem with the sensor ? Mine does not appear to be cooperating... Jim, I insalled the same sensor on mine as you but did not have an issue. But I have an aftermarket gauge and it runs about 30 degrees higher than the dipstick temperature thermometer. I wonder if you just have a bad wire, ? |
jim_hoyland |
Apr 28 2015, 08:09 AM
Has anyone installed the Jonsey billet tuna can and had a problem with the sensor ? Mine does not appear to be cooperating... Jim, I insalled the same sensor on mine as you but did not have an issue. But I have an aftermarket gauge and it runs about 30 degrees higher than the dipstick temperature thermometer. I wonder if you just have a bad wire, ? Good possibility. Gonna check it tomorrow when I reach San Simeon. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:15 AM |
