WTB Radio dash/face plate, for '71 |
Cairo94507 |
May 3 2015, 05:34 PM
Michael Group: Members Posts: 9,713 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
914Sixer |
May 3 2015, 07:41 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Post a picture of the front, that will help everyone.
Cairo94507 |
May 3 2015, 08:05 PM
Here is what I am looking for- it is just the flat plate with the black dash material on it. (I already have the radio (IMG:style_emoticons/default/blink.gif))
Cairo94507 |
May 4 2015, 07:07 AM
I know someone has one of these collecting dust....
Tom_T |
May 4 2015, 01:41 PM
Michael - you can also check over on TheSamba Porsche section for these odds-n-ends types of parts.
The "official" 914 faceplate supplied with the radio would've been in molded plastic (where's Mikey914 when you need him!? ;-) so look for that if you're doing serious AACA/etc. concours & PCA Parade where originality counts. You can also get the roll of basketweave black dash material from Sierra Madre & others, then cut & adher to the metal faceplate if you have one (IIRC you had a dealer prep'd one with smooth leatherette on metal plate). If the dealer did a metal plate with vinyl on the original install - or you want to use that "story" - then you're still probably okay for Parade/other orignality checks. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Cairo94507 |
May 4 2015, 03:28 PM
stevegm |
May 4 2015, 04:13 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
Let me see if I have it. We just bought 5 more parts cars that we will pick up this weekend. I can look for the plate with the correct weave.
Cairo94507 |
May 4 2015, 05:35 PM
I would really appreciate that Steve. Thanks, Michael
914Sixer |
May 4 2015, 07:41 PM
AA has the plates, then you cover it with dash material.
Cairo94507 |
May 4 2015, 09:19 PM
I checked AA and saw a picture of one.....maybe it was just a really really bad one....but it was bad enough in appearance I would not install it if it were free unfortunately. But I do appreciate the idea.
McMark |
May 4 2015, 11:59 PM
I have some that I had laser cut, and I have material. You'll have to glue it on yourself though. (IMG:style_emoticons/default/wink.gif)
Mike Fitton |
May 5 2015, 07:48 AM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
I will check and see what I got. There is a difference depending on which chrome trim piece you use. The picture you posted was one of my radios and that trim piece installs from the front, which trim piece are you using? Picture below shows a different trim piece that pushes through the cutout in the dash trim/faceplate and the hole cutout needs to be a little bigger.
Cairo94507 |
May 5 2015, 01:33 PM
914Sixer |
May 6 2015, 05:56 AM
Your radio is complete. Center hole needs to be big enough for the chrome surround to fit through.
Cairo94507 |
May 6 2015, 06:24 AM
OK- at least that is good news. Thanks Mark.
Mike Fitton |
May 6 2015, 02:58 PM
Sorry only faceplate I have is for the chrome trim that mounts from the front and opening is too small for the push through one.
rgalla9146 |
May 6 2015, 07:30 PM
Cairo ? Michael ?
The correct dash plate for that radio is basket weave material over sheet metal that has factory holes for shafts and dial. It is not molded plastic. The picture in post # 3 is the right one. The original had strips of double face foam tape around the perimeter of the back to attach it to the dash. You will also need the "U" shape bracket that supports the rear of the radio. Your next challenge is to find a correct antenna and antenna support for under the drivers front fender. Need pictures ? Rory |
914Next |
May 6 2015, 08:26 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Cairo ? Michael ? The correct dash plate for that radio is basket weave material over sheet metal that has factory holes for shafts and dial. It is not molded plastic. The picture in post # 3 is the right one. The original had strips of double face foam tape around the perimeter of the back to attach it to the dash. You will also need the "U" shape bracket that supports the rear of the radio. Your next challenge is to find a correct antenna and antenna support for under the drivers front fender. Need pictures ? Rory So….sounds like there is disagreement as the whether the original plate was molded plastic with the weave pattern in it, or vinyl over a metal plate. I'm looking for one also and want it to be original…plastic or vinyl? Tom, I think it was mine you may have been referring to…it has the smooth vinyl on a metal plate which was installed originally by the dealer. |
Cairo94507 |
May 6 2015, 09:26 PM
I believe the correct face plate for my radio is the flat sheet metal with the basketweave material glued to it and the opening to allow the radio to fit through it. I believe I have now secured the correct piece thanks to Sixnotfour. (IMG:style_emoticons/default/aktion035.gif)
Mike Fitton |
May 7 2015, 07:46 AM
Plastic faceplate is for install of the Motorola Sapphire radio which would have been installed at the dealer. If Blaupunkt or Becker radio was installed then the sheet metal with basket weave material was used.
Lo-Fi Version | Time is now: 25th April 2024 - 09:34 AM |
