WTB Radio dash/face plate, for '71 |
Cairo94507 |
May 3 2015, 05:34 PM
Michael Group: Members Posts: 9,778 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
rgalla9146 |
May 6 2015, 07:30 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Cairo ? Michael ?
The correct dash plate for that radio is basket weave material over sheet metal that has factory holes for shafts and dial. It is not molded plastic. The picture in post # 3 is the right one. The original had strips of double face foam tape around the perimeter of the back to attach it to the dash. You will also need the "U" shape bracket that supports the rear of the radio. Your next challenge is to find a correct antenna and antenna support for under the drivers front fender. Need pictures ? Rory |
914Next |
May 6 2015, 08:26 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Cairo ? Michael ? The correct dash plate for that radio is basket weave material over sheet metal that has factory holes for shafts and dial. It is not molded plastic. The picture in post # 3 is the right one. The original had strips of double face foam tape around the perimeter of the back to attach it to the dash. You will also need the "U" shape bracket that supports the rear of the radio. Your next challenge is to find a correct antenna and antenna support for under the drivers front fender. Need pictures ? Rory So….sounds like there is disagreement as the whether the original plate was molded plastic with the weave pattern in it, or vinyl over a metal plate. I'm looking for one also and want it to be original…plastic or vinyl? Tom, I think it was mine you may have been referring to…it has the smooth vinyl on a metal plate which was installed originally by the dealer. |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:46 AM |
