starting problem |
starting problem |
rosenfe |
May 4 2015, 09:26 AM
Senior Member Group: Members Posts: 549 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
on my 73.when i turn key i hear fuel pump,when i turn to engage starter,sometimes it will engae,other times starter will just click or turn a few turns and other times it fully engages and starts car.new starter one week old,i replaced starter because i had problem with previous starter and it did the same thing.
ive thought maybe a bad starter switch but it does engage fuel pump every time.ive tried different batteries ,still the same symptoms car runs great and always will start eventually. any ideas.? |
Mike Bellis |
May 4 2015, 10:22 AM
The starter contacts in the switch may be bad. Very common. New switches are crap. Install a starter relay to take the electrical load off the switch to preserve it longer.
rosenfe |
May 4 2015, 10:55 AM
yes,i thought i should at least start by putting in a new starter switch.
Lo-Fi Version | Time is now: 11th May 2024 - 05:13 PM |
