Mystery Shock Washers..? |
Olympic 914 |
May 6 2015, 02:09 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Putting my rear shocks back together and I have a couple shock blow-ups but they are not clear to me which washer goes where.
diagrams Heres what I have.. at least this was what I had in the "rear shock" baggie. (not pictured is the washer that goes on above the top rubber bushing ) does it go like this.. with the big washer that looks like a fender washer? or with the smaller one that is the same size as the bottom of the threaded bushing. #5 in diagram. the smaller washer seems to have been specially machined for something like it may have gone under the lower spring retainer on the original shocks, but I am putting on KYB shocks and there is a shoulder that the top spring retainer rests against. the recess in the washer does not fit over this shoulder. |
Olympic 914 |
May 6 2015, 02:12 PM
from the drawings it looks like the stock shocks did not have this shoulder and maybe this washer rested on a step on the shock rod. but they don't show a washer there in either picture. (IMG:style_emoticons/default/confused24.gif) |
Olympic 914 |
May 6 2015, 02:16 PM
this may be the correct washer for above the spring retainer.
ChrisFoley |
May 6 2015, 02:17 PM
I am Tangerine Racing Group: Members Posts: 7,924 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The stepped washer is all that remains of the bump rubbers.
(Top end of item 8) |
Olympic 914 |
May 6 2015, 02:22 PM
bdstone914 |
May 6 2015, 05:33 PM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The rear bump stops are NLA.
Paragon |
May 6 2015, 07:37 PM
Newbie Group: Members Posts: 49 Joined: 6-February 03 From: Corpus Christi, Texas Member No.: 255 Region Association: Southwest Region |
ChrisFoley |
May 7 2015, 06:10 AM
The stepped washer is all that remains of the bump rubbers. (Top end of item 8) Hmmm, I don't have them then. is that an available part? Or can I just skip it. You need something in there to prevent the shock from bottoming out, which damages the internal valves. At a minimum, on a race car, I use a few plastic washers (made for the purpose) so the shock stops travelling before bottoming, or the Koni bump rubbers as Jason suggested. |
Olympic 914 |
May 7 2015, 06:18 AM
The rear bump stops are NLA. I just use the Koni competition bump rubbers....affordable too! I had some from the fronts that I put in. I just used contact cement and glued them into the top spring retainer. eventually I will go to bilstein rear shocks, I have bilstein for the fronts now. I will keep in mind the Koni Comp. bumpers for then. Thanks |
Lo-Fi Version | Time is now: 9th May 2024 - 05:17 PM |
