My latest project. Sanding spare top smooth, Primed & waiting for some synergy green paint |
JRust |
May 7 2015, 09:05 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
So finished sanding this smooth tonight. Then did a couple primer coats. I'll sand with some fine grit. Then spray with the single stage synergy green I got put in aerosol cans. Primer is drying now. I'll get back to it tomorrow for more sanding. Want this top super smooth
Attached thumbnail(s) |
72914wrx |
May 7 2015, 09:32 PM
Member Group: Members Posts: 86 Joined: 5-January 15 From: Fresno Member No.: 18,298 Region Association: None |
So finished sanding this smooth tonight. Then did a couple primer coats. I'll sand with some fine grit. Then spray with the single stage synergy green I got put in aerosol cans. Primer is drying now. I'll get back to it tomorrow for more sanding. Want this top super smooth Looks nice going to do the same with my top. |
toon1 |
May 7 2015, 09:38 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
if you are using primer fillers, let it shrink for a few days before painting.
I painted my top also, I think the car looks better. with the black top and the black rockers and valances it looks too cut up |
brant |
May 7 2015, 09:40 PM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I did that once. It kept cackling for years through three repaintes. Finally took it to an industrial fiberglass manufacturer. It wasn't cheap. But they gel coated it to stop the crazing.
Lo-Fi Version | Time is now: 9th May 2024 - 03:09 PM |
