Bringing Back The Dead, Restoring/Updating an old school 914-v8 Conversion |
LeftCoastErik |
May 14 2015, 09:35 AM
BADPNNY Group: Members Posts: 173 Joined: 23-March 15 From: United States Member No.: 18,555 Region Association: Northern California |
OK, so I was the *lucky* bastard who ended up with GandolfTheGrey's (previously MichaelT55's) 1972 V8 Car. Specs were as follows.
Engine: -1962 Buick 215 Aluminum V8 -STD bore, 10.5-1 (stock) comp ratio -Cyl heads-ported exhaust ports, 3 angle valve grind with hi-retainers-shaft rocker stands shortened .060"-pushrods shortened .125" for geometry correction. -Camshaft-M-488 custom ground by Shadbolt engineering(Vancouver B.C.) C/W hydraulic lifters -Spheroidal graphite iron crankshaft, 5 main journal center, thrust mains, .010" under -Rods ground .001" -New rings -Hi volume oil pump, Buick V8 filter housing -Facet electric fuel pump-GM canister filter -Offenhauser alum intake -500 cfm Edelbrock carb C/W electric choke -Buick distributor with Unilite conversion -Kennedy engineered product #1000 Buick to Porsche adapter -KEP 9" Flywheel, clutch and throw-out bearing -Custon h.d. radiator w/ twin Spals -Toyota Corolla heater TRANSMISSION: Custom built V8 side shift trans by Dr. Evil. Custom ratios 1st gear lock out Fresh rebuild, newly installed BODY: -Rayco FRP front fenders -Mitcom 916 rear quarter panels -P.B. Tweeks FRP flared rocker panels ELECTRICAL: -Hella H-4 Q.I. headlites -Eurolens rear tail lites -Tach converted to 8cyl -Mechanical oil pressure and water temp -Alpine CD -Electric windows -Updated blade style fuse blocks SUSPENSION: -H & H Carrera 19mm adj front sway bar -Addco 16mm rear sway bar -140# rear springs (100 stock) -Stock front torsion bar -Koni adj front and Koni H.D. rear shock absorbers -BMW 320i front brake conversion -Stock Porsche rear calipers -All four calipers have stainless steel liners and completely rebuilt. -Adj proportioning valve -19mm 911 master cylinder -All rotors have been crossdrilled -All flex lines are braided stainless steel -Pagio performance brake pads, all four wheels -Carrol Shelby Mini-Europa wheels 7/15 front 8.5/15 rear -Custom roll bar with rear chassis supports |
LeftCoastErik |
May 19 2015, 08:06 PM
Probably related! He came from big dog rescue and was expected to be 65+lbs of deer hound mix. .he's 42lbs of wire haired asshole. Loves us and great with my 3yr old but is hit or mostly miss with strangers and other dogs
Lo-Fi Version | Time is now: 16th May 2024 - 09:25 PM |
