Bringing Back The Dead, Restoring/Updating an old school 914-v8 Conversion |
LeftCoastErik |
May 14 2015, 09:35 AM
BADPNNY Group: Members Posts: 173 Joined: 23-March 15 From: United States Member No.: 18,555 Region Association: Northern California |
OK, so I was the *lucky* bastard who ended up with GandolfTheGrey's (previously MichaelT55's) 1972 V8 Car. Specs were as follows.
Engine: -1962 Buick 215 Aluminum V8 -STD bore, 10.5-1 (stock) comp ratio -Cyl heads-ported exhaust ports, 3 angle valve grind with hi-retainers-shaft rocker stands shortened .060"-pushrods shortened .125" for geometry correction. -Camshaft-M-488 custom ground by Shadbolt engineering(Vancouver B.C.) C/W hydraulic lifters -Spheroidal graphite iron crankshaft, 5 main journal center, thrust mains, .010" under -Rods ground .001" -New rings -Hi volume oil pump, Buick V8 filter housing -Facet electric fuel pump-GM canister filter -Offenhauser alum intake -500 cfm Edelbrock carb C/W electric choke -Buick distributor with Unilite conversion -Kennedy engineered product #1000 Buick to Porsche adapter -KEP 9" Flywheel, clutch and throw-out bearing -Custon h.d. radiator w/ twin Spals -Toyota Corolla heater TRANSMISSION: Custom built V8 side shift trans by Dr. Evil. Custom ratios 1st gear lock out Fresh rebuild, newly installed BODY: -Rayco FRP front fenders -Mitcom 916 rear quarter panels -P.B. Tweeks FRP flared rocker panels ELECTRICAL: -Hella H-4 Q.I. headlites -Eurolens rear tail lites -Tach converted to 8cyl -Mechanical oil pressure and water temp -Alpine CD -Electric windows -Updated blade style fuse blocks SUSPENSION: -H & H Carrera 19mm adj front sway bar -Addco 16mm rear sway bar -140# rear springs (100 stock) -Stock front torsion bar -Koni adj front and Koni H.D. rear shock absorbers -BMW 320i front brake conversion -Stock Porsche rear calipers -All four calipers have stainless steel liners and completely rebuilt. -Adj proportioning valve -19mm 911 master cylinder -All rotors have been crossdrilled -All flex lines are braided stainless steel -Pagio performance brake pads, all four wheels -Carrol Shelby Mini-Europa wheels 7/15 front 8.5/15 rear -Custom roll bar with rear chassis supports |
LeftCoastErik |
Jun 4 2015, 01:12 PM
I decided that the old, hammered relay board and associated wiring had to go. The Buick actually had a Porsche alternator on it (anybody need one?) so I am going to a custom case, lightweight, 1-wire alternator that Dean's Electric is building for me. Since most of the relay board that I would have been using is pass through wiring anyway, I will solder everything up. Fuel pump will be right by the fuel tank and I can use the Atomic EFI to manage power to it. I found 3 broken wires in the main harness, two of which were for rear lights, so I am glad I took the time to do this.
Attached thumbnail(s) |
whitetwinturbo |
Jun 4 2015, 04:26 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
I decided that the old, hammered relay board and associated wiring had to go. The Buick actually had a Porsche alternator on it (anybody need one?) so I am going to a custom case, lightweight, 1-wire alternator that Dean's Electric is building for me. Since most of the relay board that I would have been using is pass through wiring anyway, I will solder everything up. Fuel pump will be right by the fuel tank and I can use the Atomic EFI to manage power to it. I found 3 broken wires in the main harness, two of which were for rear lights, so I am glad I took the time to do this. Now that takes patience! |
Lo-Fi Version | Time is now: 16th May 2024 - 08:46 PM |
