new car, first post |
arsprod |
May 14 2015, 11:41 AM
Member Group: Members Posts: 199 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
Newbie on the 914 board - just bought a '74 2.0 from my uncle (who bought the car new). It's actually in transit from Florida and supposed to arrive tomorrow. In anticipation of its arrival (and my desire to get it on the road asap) I'm looking for some guidance.
The car's been sitting. He started it monthly and let the oil come to temp but other than moving onto the transporter it's really not been run much. I'm planning to change the oil right away and probably flushing brake fluid, inspecting pads, and replacing ignition parts in the next couple weeks. Anything else I should be aware of? I'm not unfamiliar with VW engines but it's been awhile and never owned a 914 (though lusted for years!). Thanks in advance. Aaron in Indianapolis |
somd914 |
May 14 2015, 05:44 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Agree with fluid changes, tuneup, brake and tire check as first order of business.
Also agree that rust in the longs can be a killer, typically right side suffers thanks to the battery. Pull the rocker panels to clean out debris and for a good look at the longs. I'd also get rid of the gas in the tank and fill her up with fresh. I know it was mentioned to examine your fuel lines including those in the tunnel, and if original they are plastic and prone to fail in their old age - plan on installing stainless tunnel lines as a needed upgrade. Lots to do potentially, but once you start driving her you'll figure out what is good, what is in need of repair at some point, and what needs to be repaired right away. Not only does he throw a BBQ, Garold is a good source for used parts, and Brad Mayuer of 914 Limited (and a member here) over in Illinois has a good reputation for repairs . And the list goes on and on for members who are also vendors - you'll learn them in time. Welcome to the madness! |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:50 AM |
