new car, first post |
arsprod |
May 14 2015, 11:41 AM
Member Group: Members Posts: 199 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
Newbie on the 914 board - just bought a '74 2.0 from my uncle (who bought the car new). It's actually in transit from Florida and supposed to arrive tomorrow. In anticipation of its arrival (and my desire to get it on the road asap) I'm looking for some guidance.
The car's been sitting. He started it monthly and let the oil come to temp but other than moving onto the transporter it's really not been run much. I'm planning to change the oil right away and probably flushing brake fluid, inspecting pads, and replacing ignition parts in the next couple weeks. Anything else I should be aware of? I'm not unfamiliar with VW engines but it's been awhile and never owned a 914 (though lusted for years!). Thanks in advance. Aaron in Indianapolis |
Java2570 |
May 16 2015, 10:31 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
It would be a great idea to look at replacing all your rubber fuel hoses as well as the center tunnel hard lines that run through the center tunnel to the gas tank. Also, look at rust inside the fuel tank. Tangerine Racing sells nice stainless steel line sets for fuel and so does Rotary'14 (914World member). I replaced all my lines and cleaned out my tank last summer and was horrified with the condition of all the rubber lines. Ethanol fuels are not kind to rubber lines not rated for it's use....make sure to get 30R9 rubber fuel lines.
We are great at spending your money!! (IMG:style_emoticons/default/beer.gif) |
earossi |
May 16 2015, 04:22 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
It would be a great idea to look at replacing all your rubber fuel hoses as well as the center tunnel hard lines that run through the center tunnel to the gas tank. Also, look at rust inside the fuel tank. Tangerine Racing sells nice stainless steel line sets for fuel and so does Rotary'14 (914World member). I replaced all my lines and cleaned out my tank last summer and was horrified with the condition of all the rubber lines. Ethanol fuels are not kind to rubber lines not rated for it's use....make sure to get 30R9 rubber fuel lines. We are great at spending your money!! (IMG:style_emoticons/default/beer.gif) What makes you blame the degradation of rubber fuel lines on ethanol? You may have ethanol confused with methanol, used years ago, which did attack rubber. At 40 years old I suspect that most rubber is at end of life due to ozone....not ethanol. |
Lo-Fi Version | Time is now: 17th May 2024 - 10:10 PM |
