new car, first post |
arsprod |
May 14 2015, 11:41 AM
Member Group: Members Posts: 199 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
Newbie on the 914 board - just bought a '74 2.0 from my uncle (who bought the car new). It's actually in transit from Florida and supposed to arrive tomorrow. In anticipation of its arrival (and my desire to get it on the road asap) I'm looking for some guidance.
The car's been sitting. He started it monthly and let the oil come to temp but other than moving onto the transporter it's really not been run much. I'm planning to change the oil right away and probably flushing brake fluid, inspecting pads, and replacing ignition parts in the next couple weeks. Anything else I should be aware of? I'm not unfamiliar with VW engines but it's been awhile and never owned a 914 (though lusted for years!). Thanks in advance. Aaron in Indianapolis |
Han Solo |
May 18 2015, 12:37 PM
Member Group: Members Posts: 288 Joined: 30-September 13 From: Middle Tennessee Member No.: 16,456 Region Association: South East States |
Even if there's little or no rust under the rocker covers - there's certainly dirt and rocks thrown up in there unless the car was never driven. You want to get that junk out because that's what captures the moisture and promotes the rust. There's a couple of other spots prone to that condition - in the front wheel wells behind the door jamb, the rear wheel wells below the sail and all the way to the rear behind the tail lights. Blow those areas out with pressurized air. If the car has dealer applied under coating (called Ziebart back in the day) that stuff is really bad after 40 yrs. with cracking and capturing moisture. Removing it is a major task unfortunately.
That's a good looking 914 and I'm sure you'd like to keep it that way. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:01 PM |
