914 Swapmeet May 17th 8AM-12 in San Jose, Anyone going? |
matthepcat |
May 14 2015, 12:07 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Anyone planning to check out the 914 swap meet in San Jose Sunday May 17th?
http://sfbay.craigslist.org/sby/cto/5019326230.html (IMG:http://www.914world.com/bbs2/uploads_offsite/s4.postimg.org-11125-1431626860.1.jpg) Located on the corner of Stevens Creek & Saratoga Ave. (IMG:http://www.914world.com/bbs2/uploads_offsite/s1.postimg.org-11125-1431626860.2.png) |
EdwardBlume |
May 14 2015, 12:11 PM
Thinking about it. I have a boat load of parts, but the PH swap is closer and bigger.
LeftCoastErik |
May 14 2015, 12:13 PM
BADPNNY Group: Members Posts: 173 Joined: 23-March 15 From: United States Member No.: 18,555 Region Association: Northern California |
I a bringing a bunch of parts in my truck and the 73 on the trailer. Rob, what is the PH swap?
matthepcat |
May 14 2015, 12:14 PM
Thinking about it. I have a boat load of parts, but the PH swap is closer and bigger. Why not go to both the Parts Heaven & Saratoga swap? (IMG:style_emoticons/default/biggrin.gif) |
matthepcat |
May 14 2015, 12:16 PM
I a bringing a bunch of parts in my truck and the 73 on the trailer. Rob, what is the PH swap? https://www.partsheaven.com/default.asp |
LeftCoastErik |
May 14 2015, 12:20 PM
I'll add that to the calendar also
EdwardBlume |
May 14 2015, 12:45 PM
Thinking about it. I have a boat load of parts, but the PH swap is closer and bigger. Why not go to both the Parts Heaven & Saratoga swap? (IMG:style_emoticons/default/biggrin.gif) Kids, ball and chain.... Just kidding. More like church! |
bfrymire |
May 15 2015, 11:36 AM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Not sure if I can make it or not. Too busy this weekend, which is too bad, as I was looking forward to going!
I need to go and see if I have anything that I want to get rid of... -- brett |
Mike Bellis |
May 15 2015, 12:00 PM
Maybe
matthepcat |
May 15 2015, 12:13 PM
I am going to try and find a back pad, and a few other items for my car.
Elliot Cannon |
May 15 2015, 01:15 PM
I'll be up that way for the Makers Fair. Will maybe stop by for a short while.
LeftCoastErik |
May 16 2015, 06:51 PM
Got the 73 on a trailer and I'm bringing a single weber kit, rear spoiler, the mini lites and the front struts with drilled rotors and 320 calipers
kkid |
May 16 2015, 08:24 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
I will be there.
I am looking for a LE spoiler. |
matthepcat |
May 16 2015, 08:33 PM
I will be bringing a box of random hvac parts.
See you folks tomorrow morning. |
Mike Bellis |
May 16 2015, 09:05 PM
Ok, I'm coming for no reason than to see 914's (IMG:style_emoticons/default/biggrin.gif)
matthepcat |
May 16 2015, 09:20 PM
Mike Bellis |
May 17 2015, 01:16 PM
I made it all the way home. Right at the bottom of my driveway the car dies and would not restart. Not sure what the issue is now but I'm leaning toward the fuel pump. I had to use the starter in 1st gear to get it up the driveway and into the gargae... (IMG:style_emoticons/default/dry.gif)
Mike Bellis |
matthepcat |
May 17 2015, 04:20 PM
Bummer. Eventually if you swap out enough parts it will be indestructible.
Michael N |
May 17 2015, 05:01 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
I made it all the way home. Right at the bottom of my driveway the car dies and would not restart. Not sure what the issue is now but I'm leaning toward the fuel pump. I had to use the starter in 1st gear to get it up the driveway and into the gargae... (IMG:style_emoticons/default/dry.gif) Geez Mike....I guess that tow bar wouldn't help you in your own drive way. |
Lo-Fi Version | Time is now: 13th May 2024 - 06:38 PM |
