Bigger cylinder/piston options for us 1.7/1.8 guys besides 96's? |
Mueller |
May 14 2015, 04:44 PM
Seems all the bigger piston and cylinder kits on AA or EMW is geared towards the 2.0 based motors with the longer stroke.
Is there a reason for this besides people just wanting to maximize the CC of their motor build money? |
TheCabinetmaker |
May 14 2015, 05:45 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Very good question. I await the answer.
Bob L. |
May 14 2015, 06:13 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
The cases are all the same. As long as it is good condition you can start with a 1.7, 1.8 or 2.0.
IIRC Jake said he likes the 1.7 cases because they have had an easier life. I'm not qouteing him, but something like that. 2.0's have a longer crank (71 vs 66mm)but if you want more than 71mm stroke, you're replaceing it anyway. Otherwise it's just P's&C's, head work, exhaust, wideband... (IMG:style_emoticons/default/beer.gif) |
Mueller |
May 14 2015, 09:41 PM
The cases are all the same. As long as it is good condition you can start with a 1.7, 1.8 or 2.0. IIRC Jake said he likes the 1.7 cases because they have had an easier life. I'm not qouteing him, but something like that. 2.0's have a longer crank (71 vs 66mm)but if you want more than 71mm stroke, you're replaceing it anyway. Otherwise it's just P's&C's, head work, exhaust, wideband... (IMG:style_emoticons/default/beer.gif) It seems the pistons that are in the kits are for the longer stroke...sure new pistons can be made for the shorter stroke crankshaft, but I would think the price would be higher...or perhaps not? |
McMark |
May 14 2015, 10:03 PM
Bigger cylinders have sealing issues.
Jake Raby |
May 15 2015, 07:26 AM
LN will make a piston with any pin height that you desire.
I have a 69X106.3 combo that works great using the 17/1800 rod length ands I have also done this with a factory 66 stroke crank, using the 105.07mm bore size. Head sealing is an issue when using cylinders and hardware outside the Nickies line up. In general I prefer stroke over bore hen increasing displacement. |
May 15 2015, 07:30 AM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The cases are all the same. As long as it is good condition you can start with a 1.7, 1.8 or 2.0. IIRC Jake said he likes the 1.7 cases because they have had an easier life. I'm not qouteing him, but something like that. 2.0's have a longer crank (71 vs 66mm)but if you want more than 71mm stroke, you're replaceing it anyway. Otherwise it's just P's&C's, head work, exhaust, wideband... (IMG:style_emoticons/default/beer.gif) It seems the pistons that are in the kits are for the longer stroke...sure new pistons can be made for the shorter stroke crankshaft, but I would think the price would be higher...or perhaps not? you can get any pin height forged piston you want from the typical piston manufacturers.... I have JE pistons, and you call them to give them all the details you want, they are made to order if you want, but they do stock some normal sizes Get you head into Chevy and measure up those....the stuff is available cheaper and some of the sizes are close to what we want. (pistons) BUT, you should still stuff the motor in there and get it running so you can drive it....its fast enough to get you in plenty of trouble. rich |
toon1 |
May 15 2015, 11:04 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Not much of interest in short stroke for these engines would be my guess.
the one engine build that still really intrigues me is the 78mm stroke with the 90.5mm bore. a torquey gas mizer this was the basis for Jakes super two liter, |
euro911 |
May 16 2015, 02:00 AM
Dilemma - I'm in the process of tearing my wife's 1.7L D-jet motor apart for a rebuild. At first, I was going to rebuild what was in there - bone stock.
Recently, I've thought about going a little bigger, but want to keep the existing FI system pretty much as is and keep the car fairly reliable (whatever that means, being a 914) (IMG:style_emoticons/default/laugh.gif) If the 66mm crank and rods check out OK, maybe just a little increase with 94mm P&Cs and a little more aggressive cam. Is this a wise choice? … and an experienced FI guru can list any pitfalls I may encounter? (IMG:style_emoticons/default/popcorn[1].gif) |
May 16 2015, 07:17 AM
You will need to do head work on those heads, or do yourself a favor and get new AMC castings for the 1.8 heads and port design.
Then get a set of 96mm pistons and cylinders from EMW... Simple build |
Lo-Fi Version | Time is now: 28th May 2024 - 06:38 PM |
