Braking Question, or breaking question.....about brakes |
db9146 |
May 14 2015, 06:04 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
My -6 has PMB-rebuilt 911SC front and rear 914-6 calipers (from just back in December 2014) with old braided lines, a 19MM MC, Porterfield R4S pads, and an adjustable KH brake proportioning valve replacing the stock Porsche unit. I found today that the braid on one of the lines has fatigued and broken so I need to replace the lines immediately. The braking "bite" is not what I like so I'm looking to improve it but maybe a new MC will help if this one is leaking a little (just saw this today).
So..... 1) Would you replace the braided lines with more braided lines and then keep a watch on them and replace in another few years or go with good quality (ATE) rubber lines? and 2) would you replace the stock -6 19MM master cylinder with a new 19MM or move up to a 23MM because of the larger SC front calipers? I'm hoping Eric will weigh in here and give us all the straight scoop. This is a stock 2L -6 for driving and some AX (7s & 8s x 16 Fuchs). |
May 14 2015, 06:15 PM
914-6 GT in waiting Group: Members Posts: 19,270 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Rubber lines
Larger 23 mc will provide less power and be very stiff. |
Larmo63 |
May 14 2015, 06:25 PM
Lo-Fi Version | Time is now: 14th May 2024 - 02:31 PM |
