| saigon71 |
May 15 2015, 08:29 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,019 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
The last thing I have to adjust to resolve my occasional bucking issue it the fuel pressure. New TPS board set properly, distributor pulled apart, cleaned & lubed. Engine in a fine state of tune with no vacuum leaks. Timing is spot on.
The car is running like a bat out of hell aside from this occasional buck. The Haynes manual says 28.4 to 29.6. Mine is set at 29. I run whatever gas is available...mostly ethanol "enhanced." What fuel pressure are my fellow d-jetters running? Thanks! |
| SLITS |
May 15 2015, 08:41 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I always set them at 29 - 30 psig. I have run as high as 34 psig, but backed it down so as not to override the spring in the injector.
| worn |
May 15 2015, 08:17 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,506 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest
The last thing I have to adjust to resolve my occasional bucking issue it the fuel pressure. New TPS board set properly, distributor pulled apart, cleaned & lubed. Engine in a fine state of tune with no vacuum leaks. Timing is spot on. The car is running like a bat out of hell aside from this occasional buck. The Haynes manual says 28.4 to 29.6. Mine is set at 29. I run whatever gas is available...mostly ethanol "enhanced." What fuel pressure are my fellow d-jetters running? Thanks! I wouldn't touch it if that is where you are at. Look elsewhere for the bucking. |
Lo-Fi Version | Time is now: 5th December 2025 - 08:23 AM |
