Swapping Out The Control Arms, What to Watch Out For? |
Mblizzard |
May 15 2015, 05:14 PM
Seems pretty simple. Going to read through the Haynes Manual of course. But thought I would ask if anyone has tips? Any special tools? Got new set built up with new bushings, ball joints, new nuts, and turbo tie rods.
Figured I would leave the shocks in place, separate at ball joint, and drop out. Will measure and set the tie rods to get close but figure I would pull the rack to clean up everything. Will get some ride height measurement and such. Seems too easy! |
Larmo63 |
May 18 2015, 05:35 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Ball joints are supposed to be über tight of course, but you do have the lock discs below them as insurance.
A good tire/alignment shop should be able to do them for you off the car also. |
Mblizzard |
May 18 2015, 05:47 PM
Ball joints are supposed to be über tight of course, but you do have the lock discs below them as insurance. A good tire/alignment shop should be able to do them for you off the car also. Got all new parts so got the new lock disks as well. I will have to have it aligned of course so I might have the shop tighten then up. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:13 PM |
