temp gauge |
temp gauge |
arsprod |
May 17 2015, 04:26 PM
Member Group: Members Posts: 199 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
The temp gauge above my fuel gauge isn't working. For the life of me I cannot find any mention of it in the Haynes manual I have or even in the owners manual. Where's the sending unit for this thing? 74 2.0
914Sixer |
May 17 2015, 07:30 PM
914 Guru Group: Members Posts: 8,892 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Wire is green with red stripe. Heat and time have caused most of the wires to get brittle and break under the sheath giving you no reading at the gauge.
arsprod |
May 23 2015, 11:28 AM
Wire is green with red stripe. Heat and time have caused most of the wires to get brittle and break under the sheath giving you no reading at the gauge. Could it be green/black on 74? There's 1 wire under battery box that's not going to the fuel pump and it's green/black. From my reading in Haynes manual that's correct |
type47 |
May 23 2015, 03:48 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Could it be green/black on 74? http://www.pelicanparts.com/914/parts/Elec...lectric_74D.jpg G8 and G9 are temp sender and temp indicator and the wire is indeed green/blk (track 53 and 54) Legend: http://www.pelicanparts.com/914/parts/Elec...lectric_74F.jpg |
arsprod |
May 23 2015, 06:13 PM
Could it be green/black on 74? http://www.pelicanparts.com/914/parts/Elec...lectric_74D.jpg G8 and G9 are temp sender and temp indicator and the wire is indeed green/blk (track 53 and 54) Legend: http://www.pelicanparts.com/914/parts/Elec...lectric_74F.jpg Great thanks. So, I'm assuming if I either ground or put power to the wire going to the gauge it should give a reading or move? I get continuity to the taco but nothing back to the gauge. |
Lo-Fi Version | Time is now: 27th May 2024 - 10:41 AM |
