> temp gauge
arsprod
post May 17 2015, 04:26 PM
Post #21
The temp gauge above my fuel gauge isn't working. For the life of me I cannot find any mention of it in the Haynes manual I have or even in the owners manual. Where's the sending unit for this thing? 74 2.0
arsprod   temp gauge   May 17 2015, 04:26 PM
type47   Where's the sending unit for this thing? L...   May 17 2015, 05:28 PM
arsprod   Thank you! I was looking at that yesterday tho...   May 17 2015, 05:33 PM
914Sixer   Wire is green with red stripe. Heat and time have...   May 17 2015, 07:30 PM
arsprod   Wire is green with red stripe. Heat and time hav...   May 23 2015, 11:28 AM
type47   Could it be green/black on 74? http://www.peli...   May 23 2015, 03:48 PM
arsprod   Could it be green/black on 74? http://www.pel...   May 23 2015, 06:13 PM
SKL1   Get a new sending unit for the taco plate and put ...   May 23 2015, 09:25 PM
steuspeed   ... I sent my gauge to North Hollywood Speedomet...   May 24 2015, 01:08 AM
arsprod   Get a new sending unit for the taco plate and put...   May 24 2015, 06:57 AM
arkitect   Get a new sending unit for the taco plate and put...   May 24 2015, 08:24 AM
arsprod   This the correct part? http://www.egauges.com/Prod...   May 24 2015, 07:44 AM
Java2570   This the correct part? http://www.egauges.com/Pro...   May 24 2015, 08:43 AM
bdstone914   [quote name='arsprod' post='2190641' date='May 24...   May 24 2015, 12:08 PM
brant   I am facing the same problem is there anyway to te...   May 24 2015, 10:07 AM
bdstone914   Measure the resistance from the center terminal to...   May 24 2015, 12:03 PM
Java2570   This thread has a ton of good oil temp info: http:...   May 24 2015, 02:56 PM
arsprod   Hmm... maybe just replacing wire is the answer   May 24 2015, 05:55 PM
SKL1   Here's a picture of the gauge panel before I p...   May 24 2015, 06:36 PM
arsprod   So I've confirmed a connection from sender to ...   May 31 2015, 07:56 AM
forrestkhaag   I recently went thru this issue with my newly rewo...   May 31 2015, 08:54 AM
arsprod   I recently went thru this issue with my newly rew...   May 31 2015, 09:00 AM
arsprod   Back at this - I've ordered a sender finally b...   Jun 14 2015, 03:21 PM
stugray   + to +12VDC (dash power) GND to chassis ground Th...   Jun 14 2015, 04:00 PM
arsprod   + to +12VDC (dash power) GND to chassis ground T...   Jun 14 2015, 05:40 PM
stugray   Thank you - appears mine is missing a lead to gr...   Jun 14 2015, 06:57 PM
arsprod   Thank you - appears mine is missing a lead to g...   Jun 15 2015, 08:17 AM
arsprod   Follow up with some potentially helpful info for f...   Jun 22 2015, 10:15 AM
stugray   - the wire from the sender to my gauge was disco...   Jun 22 2015, 12:48 PM
arsprod   - the wire from the sender to my gauge was disc...   Jun 22 2015, 01:15 PM
stugray   Thanks, me too! Just noticed your signature -...   Jun 22 2015, 04:04 PM
arsprod   Thanks, me too! Just noticed your signature ...   Jun 22 2015, 05:51 PM
- Lo-Fi Version Time is now: 14th April 2026 - 06:02 PM
