60 days left, are you ready?, What do you have left to do? |
skline |
Feb 21 2005, 02:25 AM
I will start, I have to change out the front and rear shocks on the 74, install front and rear sway bars, tires, some body work and primer, front steering fixes like tie rods and ball joints, check the brakes, they feel weak and change out the heat exchangers and install the 2 liter ones with muffler, install front fiberglass bumper, euro lenses all the way around and replace a few hoses. The Chalon, I am still waiting for the rear roller control arm bushings, I need to swap out one front strut, bleed the brakes again, alignment on front and rear, finish installing the carpet and speakers, block and primer the body, secure the battery, trunk release, rear Porsche reflector, Engman pedals, and weather striping. Of course I need to go back through and double check everything and then dial the engine in so it runs perfect. Or as perfect as I can get. Its going to be close. Hopefully some of the boys will come help me out with some of it.
Dr Evil |
Feb 21 2005, 02:48 AM
Send me your transmission! Group: Members Posts: 22,993 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Pay, register...oh ya, and make my car run (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Brando |
Feb 21 2005, 04:18 AM
Door panels, interior, carpet, firewall carpeting, 'finish' my seat mounts, new engine, hook remote oil cooler back up, replace seals (orrh orrh!), remove seatbelt warning/start disabling system, install new speedo cable, finish gauges, new windshield new chrome trim and attachment tabs, bodywork, new battery tray, treat my 'minor' hell hole, por-15 the firewall and engine bay, paintjob and headlights.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
xsboost90 |
Feb 21 2005, 06:56 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
next 60 days..im thinking 30days and run brake lines, get mc and install, bleed, etc..., install motor, get to run, buy optic ignition, sand/strip, bodywork, primer, block,primer, block, wetsand, paint, buff, interior, seat brakets, stereo, paint wheels, clean, clean clean, tailights, rubber, headlights, rubber, markers, have dash pieces made, install, wax, wax, clean clean,...rest.
rick 918-S |
Feb 21 2005, 07:56 AM
Hey nice rack! -Celette Group: Members Posts: 20,406 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I need to reinstall my engine mount bar, (pulled it out to copy it for Larry) repair some body damage, and do some detail work like cleaning and painting etc. It's not a show car but it's just as much fun.
Mueller |
Feb 21 2005, 09:14 AM
I have to do:
new front a-arm bearings (needle bearings of course), powdercoat front arms, new vented rotors, billet front hubs possible new master cylinder due to my new calipers make 1.25" thick wheel spacer for front to slide over my 90mm wheel studs make billet adapter plate for RX-7 calipers install new headlights install side marker light (I need a drivers one) paint drivers side fender paint top of windshield frame put new seat coverings on the seats install stereo install speakers install amp install carpet replace clutch and throttle cable powdercoat rear trailing arms install bearings for suspension in the rear install rear wheel bearings new rear rotors new rear calipers install rear window replace all of the window/targa top seals build new 2.2 nickies equipped engine finish the intake system tune the new engine install C/F deck lids |
Andyrew |
Feb 21 2005, 11:07 AM
Install flares
put Edelbrock intake and holley carb on tune for 250hp (detune I should say..) Install CV. Get tires on my 17's get spacers carpet interior mount second race seat fix leak in radiator system (one of my soders has a pinhole leak) Get 916 rear bumper or cut valance out for time being. Finish front flares Finish front hoood Install new bearings in rear hubs Paint/powdercoat 17's Get 180's on rear get adjustable spring pearches Put car in primer get new front lenses (euro) Rewire car (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) new bushings on front and rear. Quit jobs so I can have time to do this (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Ya, thats what I'd really like to do... Andrew |
Series9 |
Feb 21 2005, 12:15 PM
This list is much shorter than it was on 1 Feb. Here's what's left:
WCC05 Checklist 1 Feb 2005 Items in bold complete prior to 1 Mar to put the car on the road. Engine/tranny: Install clutch helper spring on tranny Body: Rear window (Lexan) Compound paint Touch up as necessary Install bumpers Install rockers Install valences Seal for front deck Fab rear trunk panel Repaint faults under header Repaint faults in rear trunk Buy/install fog lights Grommets near oil cooler Interior: Firewall covering Install trim panels: windshield, upper hoop, roll bar horiz, roll bar verts Paint gauge surround Passenger seat Passenger seat belts Angle bar coverings Trim windshield adhesive Suspension: Plate upper suspension hardware Retighten everything Alignment/ride height Install sway bar drop links in the rear |
Demick |
Feb 21 2005, 02:49 PM
I only have one thing on my list:
1. Make sure 914 will make it there and back! Demick |
xitspd |
Feb 21 2005, 04:21 PM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
Joe,
Where did you get the Lexan rear window? Your list is getting much shorter, keep up the good work..... Dan |
TonyAKAVW |
Feb 21 2005, 04:50 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Lets see. Since December I have gotten a ton of things done on the car but I still have a few things to do. So far I have:
+Stripped down the floorpans to metal, POR-15'd them and fixed a couple rust holes by welding in new metal. +Adjusted the window cranks and door handles to operate more smoothly +installed 4 new rubber seals (engine lid, front trunk, rear-edge of window seals +Finished the carpeting +replaced the brake master cylinder +installed new flexible rubber brake lines +new seals and pads on front brakes +installed sway bar in front +replaced rear springs with 140 lb springs +replaced all four shocks +replaced fuel lines from gas tank +Fixed the "on" portion of the ignition switch +registered for WCC A few things left to do including: -redo the valve cover seals -pushrod tube seals -fix the front trunk (some big holes, some rust) -replace the targa top side seals and adjust to keep water out -get a helmet Thats about it. I figure thats two good weekends of work. One for the front trunk and one for the rest. Once this damn rain stops I can get back to work on it. -Tony |
JoeSharp |
Feb 21 2005, 06:04 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Cover the check. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Joe |
drew365 |
Feb 21 2005, 08:23 PM
I just have to:
Hope the guy that's rebuilding my engine can get it finished in time. Hope I can afford to pay him so I can get my car back. I was hoping it might be painted by then but it's not looking good so you guys will just have to contain the snickers. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
VegasRacer |
Feb 24 2005, 06:34 AM
ELVIRA Group: Benefactors Posts: 8,475 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
I would be in much better shape if I could stick to the items on my list. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Instead of working on the interior like I should be, I decided today that replacing all 4 calipers would be a good idea. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) That is something that was on my 'one day in the future' list. I came across a nice set of SC brakes, so I figured "why not now?". (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Lo-Fi Version | Time is now: 19th April 2024 - 04:05 PM |
