Front mount oil cooler, rubber hoses? |
yarin |
Jun 5 2003, 10:40 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Any comments?
Every front mount application i've seen uses Aeroquip braided steel lines. Is rubber a bad idea? Thanks |
bander |
Jun 6 2003, 07:03 AM
Newbie Group: Members Posts: 15 Joined: 10-April 03 From: New Hampshire Member No.: 556 |
Mcmaster Carr all the way.
http://www.mcmaster.com/ search on part numbers 5279k213 and 5440k113. I used 1/2" but you could go with 3/4 if you wanted to. This hose is awesome stuff and the barb fittings have nuts like the AN so they can be disconnected easily. HOSE, 5279k213 1/2"id, $2.67/ft SAE-Rated Hydraulic Rubber Hose Assemblies and Hose • Tube: Buna-N rubber • Cover: black chlorinated synthetic rubber, Mine Safety and Health Administration (MSHA)-accepted • Reinforcement: SAE 100R1-AT, one high-tensile steel wire braid; SAE 100R2-AT, two high-tensile steel wire braids • Temperature Range: -40° to +257° F Male Coupling Hydraulic service requires hose that can handle the higher pressures. These hoses meet Society of Automotive Engineers (SAE) standards and are suitable for use with petroleum-based hydraulic fluids. FITTINGS, 5440k113 $1.39 ea Brass Ball-Seat Hose Nipples Assembled Nipple A ball seating inside the nut of these nipples creates the seal, minimizing leaks that can occur with pipe thread connections. For easier installation, fitting consists of two pieces: a barbed hose stem and a separate NPSM (mechanical straight thread) female swivel nut. Just insert the barbed hose stem into the swivel nut, attach the hose to the stem, then swivel the nut onto the pipe connection. Swivel action during installation helps prevent hose from kinking. Maximum working pressure is 250 psi. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:23 AM |
