Front mount oil cooler, rubber hoses? |
yarin |
Jun 5 2003, 10:40 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Any comments?
Every front mount application i've seen uses Aeroquip braided steel lines. Is rubber a bad idea? Thanks |
J P Stein |
Jun 6 2003, 02:13 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
QUOTE(drew365 @ Jun 6 2003, 10:43 AM) I'm close to doing this project. Where's a good supplier for the SS lines and fittings and what size do yall recommend? Summit Racing. 12AN minimum. BTW, for flow: Go out and turn on your garden hose full blast. There is 4 bar thru a 1/2 inch line. The 9eleben oil pump is NOT typical. The scavenge side of the pump will put out in excess of 150 psi with cold oil & a cooler. Dunno diddly bout a t-4 pump. Bigger....right, the other end is even worser Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:28 PM |
