extra wires ?, new question |
jacksun |
May 21 2015, 03:24 PM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
ejm |
May 21 2015, 04:04 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,688 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
A - heater fan
B - oil pressure switch C - aux air regulator D+E - fatter black is coil + terminal 15, thinner one with purple stripe is tach lead, coil terminal 1 F - aux air regulator plugs into C G - hole for water tray drain tube |
May 21 2015, 04:10 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Ed beat me to it... (Also can't see the pic well with the background light here.)
--DD |
Cairo94507 |
May 21 2015, 06:10 PM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
This site is just the best. In less than an hour he had answers from two guys who know their stuff.
jacksun |
May 22 2015, 06:01 AM
yes
you guys are the best. thank you for helping this rookie as he learns. now I can mask off the car and start sanding. thank you randal |
TheCabinetmaker |
May 22 2015, 06:11 AM
The part of the harness with b,c,d,e run across the back of the engine then under the passenger side intake tubes. It will make sense after that.
jacksun |
May 22 2015, 06:16 AM
thank you mr maker,
the routing of the harness makes all the difference. thanks again randal oops, I have to weld up the extra holes in the doors from the non OEM mirrors, then I can mask. |
jacksun |
May 22 2015, 06:01 PM
ejm |
May 22 2015, 06:44 PM
Thermoswitch for the cold start valve... should be right below where it comes out of the harness
jacksun |
May 23 2015, 04:59 AM
thank you, I will look again, must be the trees and forest thing.
randal |
jacksun |
May 23 2015, 05:43 AM
found it in a box,, now, ten steps back in order to install it.
thanks again randal |
Lo-Fi Version | Time is now: 19th April 2024 - 04:37 PM |
