Is this a Thing?, E-Brake ?? |
pneuhyde |
May 23 2015, 12:43 AM
Member Group: Members Posts: 94 Joined: 24-February 05 From: San Leandro, Ca. Member No.: 3,654 Region Association: Pacific Northwest |
So my last 914 had a non-working E-Brake. Everything was hooked up, it just didn't work and because the po had informed me of the situation I just never questioned it. When the body finally rusted away I found a roller to do an engine swap with. One of the things that excited me about this roller was that it had been converted to a 911 5-lug suspension in front and the words "New Eric Shea rear calipers & bushings with 5-lug hubs" jumped out at me.
How cool - Brakes that would actually work like they were supposed to, which to me meant an E-Brake, too. No more hopping out of the car and quickly throwing a rock behind the tire !!! Well, to my surprise I still dont have a working E=Brake system. I adjusted the cables, then moved on to adjust the vent clearance and found this on the inside adjuster. On closer inspection, There appears to be nothing to adjust with behind the plug, and when I rotate the lever nothing inside appears to move and the piston does not extend to push against the disc The outside caliper adjustement worked just fine, So - "Is this a thing" to dismantle the e-brake on the inside of the caliper? |
Eric_Shea |
May 25 2015, 05:13 PM
<<- I don't seem to get a notable inner piston travel from either one when the E-brake arm is rotated - what could cause that?>>
The inner adjuster has been adjusted too far inward and the adjuster itself has been pulled up into the piston tight. It is now off the small pushrod which rests against the handbrake arm. When you get the gears, turn them clockwise to push the piston out. Turn them until you can "just" feel the piston move in the outward direction. Now your handbrake arm will work as the connection between the small pushrod and the handbrake arm are solid. <<Other problems with them: - They are missing the inside adjusters (which I understand can be replaced easily).>> They are missing the inner adjuster "gears" which slide down that shaft under the cap. As easy as stop, drop and roll. The inner adjuster itself is in the caliper and screwed in tight to the piston (too tight from what you're saying above) <<- The outside adjuster on one caliper doesn't appear to be causing the piston to move.>> More than likely due to sitting. The internal adjustment mechanism is held in the piston with a C-Clip. If the adjuster itself is bound up in the mechanism, the mechanism will simply spin in the piston shell. The best way to solve this problem is with a 4mm hex on a high speed air wrench. An air wrench reaches velocity almost instantly vs. a drill or a ratchet wrench. 1. Loosen the 13mm stop nut. 2. Remove the pads. 3. In short bursts, zip the 4mm hex in a counter-clockwise direction. That should free up the adjuster inside the mechanism. Once it's moving, use your thumb to apply pressure to the piston top as you turn the 4mm hex in a clockwise direction to pull the piston back in. "Remember" - The INNER adjusters have the same right handed thread pitch BUT... because they are driven by that gear, they will adjust in reverse. (and yes, even used inner adjuster gears are expensive...) (IMG:style_emoticons/default/sad.gif) You may need to try the air wrench trick with the inner adjuster as well. Remember "Clockwise" for those and "Counter-Clockwise" for the outer |
pneuhyde |
May 26 2015, 12:01 AM
<<- I don't seem to get a notable inner piston travel from either one when the E-brake arm is rotated - what could cause that?>> The inner adjuster has been adjusted too far inward and the adjuster itself has been pulled up into the piston tight. It is now off the small pushrod which rests against the handbrake arm. When you get the gears, turn them clockwise to push the piston out. Turn them until you can "just" feel the piston move in the outward direction. Now your handbrake arm will work as the connection between the small pushrod and the handbrake arm are solid. <<Other problems with them: - They are missing the inside adjusters (which I understand can be replaced easily).>> They are missing the inner adjuster "gears" which slide down that shaft under the cap. As easy as stop, drop and roll. The inner adjuster itself is in the caliper and screwed in tight to the piston (too tight from what you're saying above) <<- The outside adjuster on one caliper doesn't appear to be causing the piston to move.>> More than likely due to sitting. The internal adjustment mechanism is held in the piston with a C-Clip. If the adjuster itself is bound up in the mechanism, the mechanism will simply spin in the piston shell. The best way to solve this problem is with a 4mm hex on a high speed air wrench. An air wrench reaches velocity almost instantly vs. a drill or a ratchet wrench. 1. Loosen the 13mm stop nut. 2. Remove the pads. 3. In short bursts, zip the 4mm hex in a counter-clockwise direction. That should free up the adjuster inside the mechanism. Once it's moving, use your thumb to apply pressure to the piston top as you turn the 4mm hex in a clockwise direction to pull the piston back in. "Remember" - The INNER adjusters have the same right handed thread pitch BUT... because they are driven by that gear, they will adjust in reverse. (and yes, even used inner adjuster gears are expensive...) (IMG:style_emoticons/default/sad.gif) You may need to try the air wrench trick with the inner adjuster as well. Remember "Clockwise" for those and "Counter-Clockwise" for the outer Thanks again. Glad to have a few things to try this week. Steve |
Lo-Fi Version | Time is now: 20th May 2024 - 09:50 PM |
