adding a trigger wheel, had to make a bracket to fit |
crash914 |
May 23 2015, 07:18 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Went to install a 36 tooth wheel for my megasquirt.
the mounting bracket supplied would work great with a stock set up, but I forgot to mention that I am running a full flow oil pump cover set up...everything is in the way so I made a bracket and added spacers to relocate the sensor at about 90 degrees. checking the fit with the fan cover in place. close fit sensor to wheel distance. sneak peak at nickies hiding under the tin. |
McMark |
May 23 2015, 07:33 PM
Nice work. Make sure it's not going to vibrate, but otherwise it should work really well.
Lo-Fi Version | Time is now: 29th April 2024 - 04:56 AM |
