how long are stock 914 CV bolts?, are they the same length as 944Turbo? |
brant |
May 24 2015, 10:04 AM
anyone know if the bolt lengths are the same?
Krieger |
May 24 2015, 10:10 AM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
944 cvs are fatter. I dont remember by how much. I bought longer bolt for both ends. I had to trim them flush as well on the wheel end since they stuck out and hit the trailing arm.
dangrouche |
May 24 2015, 11:01 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
m8x48mm
http://www.autohausaz.com/search/product.a...%20Joint%20Bolt for 944 turbo, the parts catalog shows the same dimensions http://www.autohausaz.com/search/product.a...%20Joint%20Bolt |
May 24 2015, 11:51 AM
Resident German Group: Admin Posts: 41,639 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
anyone know if the bolt lengths are the same? No, the 944 CV bolts are longer ... (IMG:style_emoticons/default/smile.gif) |
TravisNeff |
May 26 2015, 12:42 PM
Are you doing the 944 CV conversion? If so, the 48MM bolts are a little short (as mentioned in the how to guide by another member).
I ordered a set of 50MM bolts from McMaster Carr 91290A448 PN Block Oxide class 12.9 socket head cap screw, alloy steel M8 thread , 50MM length, 1.25MM Pitch, pack of 25 |
brant |
May 26 2015, 02:18 PM
Are you doing the 944 CV conversion? If so, the 48MM bolts are a little short (as mentioned in the how to guide by another member). I ordered a set of 50MM bolts from McMaster Carr 91290A448 PN Block Oxide class 12.9 socket head cap screw, alloy steel M8 thread , 50MM length, 1.25MM Pitch, pack of 25 great info Travis! do you think 50mm's are the length to go with? anyone know the length on a 944 bolt? |
TravisNeff |
May 26 2015, 06:39 PM
Stock 944 is 48mm I believe.
Here's a couple of pics. 951 stub axle, 84 944 cv's with moon clips and stock 48mm cv bolts, and new 50mm bolts Other is an early 915 thick spline trans flange, 84 944 cv's with moon clips and stock 48mm and 50mm bolts. Obviously the 50mm bolts protrude out a bit further. The poster in the how to guide stated he used 55mm bolts, but had to trim the ends for clearance, so I went with 50's Attached thumbnail(s) |
TravisNeff |
May 26 2015, 06:41 PM
And, no Schnorr washers. 944 doesn't use them, but I did order some for the m8 bolts through McMaster, I would think I need another 1 or 2mm of bolt length to use them
Lo-Fi Version | Time is now: 16th May 2024 - 10:12 AM |
