Do any of you have this?, Two quick questions.... |
Scott S |
Jun 6 2003, 09:47 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All -
I lost something that I REALLY need. It was a initial install/set up sheet for dual Webers. I adjusted linkage and timing last night and want to start from ground zero. It was very easy to follow and worked like a champ. Does anyone have one they could email/fax me? It would be VERY appreciated (IMG:style_emoticons/default/wub.gif) Also - I checked my timing and here is what I found. With the vaccume line connected when I reved up the car the thick blade of the fan (with the elongated oval mark and center line) lines up perfectly with the notch on the shroud. As I recall this is correct - but I have lost that sheet as well! I am 100% sure these two things are together, put somewhere by me where I would not lose them. (IMG:style_emoticons/default/confused24.gif) Yes - I'm an idiot.... |
cha914 |
Jun 6 2003, 10:51 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Here are another three good webber/carb articles:
http://www.aircooled.net/gnrlsite/resource...es/carbs101.htm http://www.aircooled.net/gnrlsite/resource...es/dualcarb.htm http://www.aircooled.net/gnrlsite/resource...les/jetting.htm good luck, Tony |
Lo-Fi Version | Time is now: 14th May 2024 - 12:42 AM |
