Spring pressure of Webcam's spring kits, Over the nose valve spring pressure |
lonewolfe |
May 31 2015, 02:45 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Does anyone know what the over the nose spring pressure is for Webcam's single & dual valve spring kits? I called Webcam and the lady could only give me the seated pressure and install heights. Seems odd they couldn't provide this information. I surely can't be the first person to ask.
Do any of you have this info? |
colingreene |
May 31 2015, 03:27 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
call the lady back and ask for someone in design they should be able to tell you.
Why do you need to know though. |
lonewolfe |
May 31 2015, 04:02 PM
colingreene |
May 31 2015, 08:40 PM
Ah, i would say you should go web cam/lifters/springs.
Though they should be able to figure that out for you. |
Mark Henry |
May 31 2015, 09:12 PM
Most performance grinds I'd only go dual spring.
On my /4 in the bug, but I'm running Gene Berg type I duals, CrMo retainers, hardened keepers and steel shims. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:42 AM |
