3 Pages V  1 2 3 >
> BUILD-OFF CHALLENGE: Boxsterfan's 1974 2270, Time to get going over the next 3 months...
boxsterfan
post Jun 6 2015, 10:09 PM
914's are kewl
So today, I got started tearing down my 1974 2.0L. Started at the rear and got through almost all the interior except dash and center console area. Overall, the car looks good from a rust perspective, but I KNOW that there is rust in the hell hole and the area under the hell hole (where the original fuel pump mount location was) is pretty much gone as I can stick my hand in there. I'll get pics of that after I drop the motor some upcoming weekend.
So what's my build gonna be? I'm fairly well locked in on what I want to do. I have considered /6's (and even come close to acquiring a 3.0L), but I think in the end I am going to go with a built up 2270 motor. One of the main reasons I am going that route is that I want to be able to use 1st gear. Sound strange? Sure, even though 1st is not much of anything even on a stock 2.0L, I just love the dogleg shifting from 1st to 2nd. From reading others posts here, if I go a /6 I pretty much end up with starting in 2nd all the time.
So here's the build (with some decision points still):
Note: This is a very high level list
Staying with Narrow Body, removing the warts and antenna hole
2270 /4 with some form of FI provided by megasquirt, external oil cooler, maybe ITB's.
901 side-shift with anything that can be done to improve gearing and longevity
5-lug upgrade (suspension components and the whole bits) with Fuchs.
Interior will be mostly stock, but looking to go the Getty Dash route.
Sticking with original Alaska Blue Metallic (L96B)
Here's my progress today:
Rear bumper off:
boxsterfan
914's are kewl
Trunk shots:
boxsterfan
post Jun 6 2015, 10:11 PM
914's are kewl
Trunk corners:
boxsterfan
914's are kewl
Passenger Door:
boxsterfan
post Jun 6 2015, 10:12 PM
914's are kewl
Drivers Door:
boxsterfan
post Jun 6 2015, 10:13 PM
914's are kewl
Sail Panels:
boxsterfan
post Jun 6 2015, 10:14 PM
914's are kewl
Interior Floor pans and Firewall:
boxsterfan
post Jun 6 2015, 10:15 PM
914's are kewl
Interior and Floor Pans continued:
boxsterfan
post Jun 6 2015, 10:17 PM
914's are kewl
Sail Panel drains:
boxsterfan
post Jun 6 2015, 10:18 PM
914's are kewl
Door Jams:
JeffBowlsby
post Jun 6 2015, 10:38 PM
Nice Ron, this will be fun to watch. Will you put the tub on a rotisserie or leave it on the ground?
boxsterfan
post Jun 6 2015, 10:49 PM
914's are kewl
Thanks Jeff. I'm going to strip her down as far as I can get her and then send her out for body work. Same for the motor. There are some things that are just beyond my skill, and of course, my available time to actually work on the car. As far as i am concerned though, everything is coming off of the car.
Besides the continuing deconstruction of the car, I want to get a good look inside those longs with a camera (scope). I had the rockers off a little over a year ago, and there was some mild surface rust (very, very mild). Most worried about the passenger long of course given the hell hole and the completely rusted out panel below the hell hole where the fuel pump was originally mounted. I suspect some rust has worked it's way down inside there given the mild surface rust at the jackpoint. Pics of my longs from January 2014 are here: http://www.914world.com/bbs2/index.php?sho...=227937&hl=
billh1963
Car Hoarder!
Love this color!
sdthomas
post Jun 7 2015, 09:44 AM
Looking forward to seeing your build happen. Hope to do the same on mine some day.
-Shawn
Nemisus
post Jun 7 2015, 12:04 PM
This 74 looks like its in great shape! Looking forward to seeing progress
Cheers
Nemi
Cairo94507
post Jun 7 2015, 12:54 PM
Michael
That chassis is in terrific condition. I love the color - one of my favorites. I like that you are doing this whole car correctly by taking at all the way down and addressing any rust. Once you do that you will likely never have to worry about rust again. Look forward to seeing this car progress. Please take and post a lot of progress pictures. At some point, if you ever decide to sell the car, it is that attention to detail and the photos that will make the difference in obtaining top dollar.
francar
post Jun 7 2015, 05:20 PM
boxsterfan
post Jun 7 2015, 07:56 PM
914's are kewl
Day 2 of progress. Front of the floor pans looks good and took some shots of the rockers again which look good. However, the front hood channels and the front have some rust.
The car definitely had/has some water leakage issues up front, but looking at the hood channels, it's not a surprise.
Interior front floor pans:
boxsterfan
post Jun 7 2015, 07:58 PM
914's are kewl
Pedal cluster close-up and shot inside the tunnel at the rear:
Note: Inside the center tunnel looks just dirty as I took my finger and swiped away some dirt in the middle of the pic.
boxsterfan
post Jun 7 2015, 07:59 PM
914's are kewl
Driver's rocker:
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 18th July 2025 - 07:00 PM
