Rotary 914!, 200whp ; Prepping for Okteenerfest |
gabeurgelles |
Jun 11 2015, 07:01 PM
Member Group: Members Posts: 70 Joined: 2-February 15 From: Miami Member No.: 18,389 Region Association: None |
I recently purchased a 73' 914 with a Mazda 13b already swapped into it. I am the second owner of the car, previous owner was from Arizona. It has NO RUST at all and the swap was done properly. The motor mount and radiator frame were both very well done. As well as the plumbing from the radiator to the engine. The car also has an interesting exhaust system, which I found out although it looked cool, was not the right type of exhaust for the rotary. The passenger side rear brake caliper bleeder was broken. The swap was never completed and the car never drove under rotary power. The only thing left was fabricating a new shift linkage, since the old one would go right through the oil pan.
I bought the car purely for the condition of the body and wasnt really counting on a good engine or transmission but after messing around with it in the garage I got it running. I discovered the engine was streetported and in decent condition. The engine only had hours on it from the rebuild but it suffered from sitting for all that time. |
relentless |
Sep 24 2015, 11:26 AM
Member Group: Members Posts: 350 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
Neat looking car! Back in the day I had a '93 RX-7 twin turbo and that car was quick. Take good care of those apex seals. I think Pettit Racing sells a lube that you put in the gas, which extends apex seal life.
BillC |
Sep 24 2015, 01:55 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Neat looking car! Back in the day I had a '93 RX-7 twin turbo and that car was quick. Take good care of those apex seals. I think Pettit Racing sells a lube that you put in the gas, which extends apex seal life. Standard 2-cycle oil is all you need. Add it to the gas at the normal ratio and it'll protect the apex seals. We race a '79 RX-7 in LeMons, and we removed the stock oil injection system (because it tends to fail with catastrophic consequences) and just pre-oil the gas -- works great and no problems! We use one ounce of oil per gallon of fuel. |
Lo-Fi Version | Time is now: 10th May 2024 - 12:08 PM |
