Rotary 914!, 200whp ; Prepping for Okteenerfest |
gabeurgelles |
Jun 11 2015, 07:01 PM
Member Group: Members Posts: 70 Joined: 2-February 15 From: Miami Member No.: 18,389 Region Association: None |
I recently purchased a 73' 914 with a Mazda 13b already swapped into it. I am the second owner of the car, previous owner was from Arizona. It has NO RUST at all and the swap was done properly. The motor mount and radiator frame were both very well done. As well as the plumbing from the radiator to the engine. The car also has an interesting exhaust system, which I found out although it looked cool, was not the right type of exhaust for the rotary. The passenger side rear brake caliper bleeder was broken. The swap was never completed and the car never drove under rotary power. The only thing left was fabricating a new shift linkage, since the old one would go right through the oil pan.
I bought the car purely for the condition of the body and wasnt really counting on a good engine or transmission but after messing around with it in the garage I got it running. I discovered the engine was streetported and in decent condition. The engine only had hours on it from the rebuild but it suffered from sitting for all that time. |
gabeurgelles |
Mar 30 2016, 06:00 PM
So now it's time for suspension. I ordered Koni yellows for the front and then I'll probably end up getting the ground control kit for the rear. But looking at the front shocks, do I have touch the rubber bump stop. I know you can cut them for cars that are low and bottom out easily but is this a problem on 914s? Or is this just and easy swap of the old ones?
Planning on doing this soon so any help would be appreciated! |
Lo-Fi Version | Time is now: 9th May 2024 - 07:05 PM |
