Rotary 914!, 200whp ; Prepping for Okteenerfest |
gabeurgelles |
Jun 11 2015, 07:01 PM
Member Group: Members Posts: 70 Joined: 2-February 15 From: Miami Member No.: 18,389 Region Association: None |
I recently purchased a 73' 914 with a Mazda 13b already swapped into it. I am the second owner of the car, previous owner was from Arizona. It has NO RUST at all and the swap was done properly. The motor mount and radiator frame were both very well done. As well as the plumbing from the radiator to the engine. The car also has an interesting exhaust system, which I found out although it looked cool, was not the right type of exhaust for the rotary. The passenger side rear brake caliper bleeder was broken. The swap was never completed and the car never drove under rotary power. The only thing left was fabricating a new shift linkage, since the old one would go right through the oil pan.
I bought the car purely for the condition of the body and wasnt really counting on a good engine or transmission but after messing around with it in the garage I got it running. I discovered the engine was streetported and in decent condition. The engine only had hours on it from the rebuild but it suffered from sitting for all that time. |
gabeurgelles |
Apr 14 2016, 06:01 PM
Thank You for the instructions. The front struts went on without any major issues. The biggest issue I had was taking off the wheel bolts that the tire shop tightened. I never knew those bolts could be that tight, it broke my 3/8 ratchet, my 1/2 ratchet, and my folding tire iron!! But eventually they came off and he rest went on without an issue.
The difference that those shocks made was unbelievable. The old ones had collapsed as soon as I bought the car so I never knew what it was supposed to feel like. The rear is coming soon because I can definitely feel the back extra loose now that the font is the way it should be. |
Lo-Fi Version | Time is now: 10th May 2024 - 02:07 AM |
