Rotary 914!, 200whp ; Prepping for Okteenerfest |
gabeurgelles |
Aug 30 2016, 08:38 AM
Member Group: Members Posts: 70 Joined: 2-February 15 From: Miami Member No.: 18,389 Region Association: None |
So it was time to build an intake manifold. I started by finding some 180 degree bends with the correct radius. After a lot of looking I found what I was looking for and ended up paying around $90 for 5 bends. Since I don't have access to a machine shop, all the fabrication had to take place in my garage with everyday tools. I was able to shape the pipes by hand with a hammer and a jigsaw. I made a template/jig for the manifold of a piece of wood and shaped everything to fit that.
gabeurgelles |
Aug 30 2016, 08:39 AM
gabeurgelles |
Aug 30 2016, 08:40 AM
Rotary'14 |
Aug 30 2016, 08:55 AM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
So engine was rebuilt, everything was replaced and new carb installed. The only issue now was that on an rx7 the engine and transmission assembly sits at a 5 degree angle but on the 914 it sits dead level. So not the weber was sitting 5 degrees tilted forward which did not allow for correct tuning. If the fuel level was set correctly for one barrel, the other would either be flooding over or starving for gas. So I had two options, either tilt the engine and transmission on the 914 or make a custom manifold that would provide better flow and perfect placement for the carb. Building a manifold can be difficult in your garage without all the cool tools. (but I encourage you to expand your skills!) I bet you can get the 5 degrees you want by shimming the engine mount or the trans mount to get the tilt you want for your carb,,, or just slap on a weber throttle body onto your car the way it sits now? I love your project. |
gabeurgelles |
Aug 30 2016, 01:25 PM
gabeurgelles |
Aug 30 2016, 01:26 PM
gabeurgelles |
Aug 30 2016, 01:27 PM
matthepcat |
Aug 30 2016, 01:48 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Interesting set-up. Looks cool.
I have a heavily ported Nikki carb on mine. I have never experienced mid-corner fuel starvation, but I suppose I have not run a track day yet ( just aggressive mountain roads). These little rotaries are so fun. Like a sport bike engine. |
Rotary'14 |
Aug 30 2016, 02:00 PM
Well your manifold is done,,, Your aluminum welding skills coming along nicely there. (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif)
Andyrew |
Aug 30 2016, 02:57 PM
Great looking intake!!
mbseto |
Aug 31 2016, 12:35 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Awesome! Love seeing fabbed headers and manis, not sure why.
Mueller |
Aug 31 2016, 01:55 PM
Interesting set-up. Looks cool. I have a heavily ported Nikki carb on mine. I have never experienced mid-corner fuel starvation, but I suppose I have not run a track day yet ( just aggressive mountain roads). These little rotaries are so fun. Like a sport bike engine. I've never driven a rotary motor, are they pricey to rebuild? |
matthepcat |
Aug 31 2016, 03:37 PM
Next time I see you at an event you can drive mine.
Master rebuild kits are about $1,000 in parts. If no machining is required, its not too bad. Interesting set-up. Looks cool. I have a heavily ported Nikki carb on mine. I have never experienced mid-corner fuel starvation, but I suppose I have not run a track day yet ( just aggressive mountain roads). These little rotaries are so fun. Like a sport bike engine. I've never driven a rotary motor, are they pricey to rebuild? |
Mike Bellis |
Aug 31 2016, 06:40 PM
Looks great! Only one suggestion... Add a phenolic spacer between the carb and manifold to reduce heat soak in the carb. You don't need your fuel boiling off.
gabeurgelles |
Sep 1 2016, 08:09 AM
porschetub |
Sep 2 2016, 03:16 AM
(IMG:style_emoticons/default/unsure.gif) I've blown up enough rotaries. I'm sticking with the Audi... (IMG:style_emoticons/default/shades.gif) Post some more pics of the radiator setup. Rotaries run hot when flogged. Why do they blow up so much Mike ....never had a thing to do with them but have heard the noise a (IMG:style_emoticons/default/barf.gif) and heard they drink fuel like a elephant drinks water (IMG:style_emoticons/default/laugh.gif) . |
Mike Bellis |
Sep 2 2016, 02:18 PM
(IMG:style_emoticons/default/unsure.gif) I've blown up enough rotaries. I'm sticking with the Audi... (IMG:style_emoticons/default/shades.gif) Post some more pics of the radiator setup. Rotaries run hot when flogged. Why do they blow up so much Mike ....never had a thing to do with them but have heard the noise a (IMG:style_emoticons/default/barf.gif) and heard they drink fuel like a elephant drinks water (IMG:style_emoticons/default/laugh.gif) . Heat and pre-ignition and the weak links on a rotary. If you can control those, they run and drive wonderfully. |
ablesnead |
Sep 2 2016, 02:33 PM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
I have driven and raced against 12 a and 13 B. Rotaries for many years....In ITS trim , 180 to 200 hp they were by a factor of 3 the most reliable engine available...I have no experience with turbomotors....if you are looking for that range of HP in a 914....they are worthy of real consideration, should
Be very 901 friendly with their torque characteristics..... |
andys |
Sep 2 2016, 02:43 PM
So it was time to build an intake manifold. I started by finding some 180 degree bends with the correct radius. After a lot of looking I found what I was looking for and ended up paying around $90 for 5 bends. Since I don't have access to a machine shop, all the fabrication had to take place in my garage with everyday tools. I was able to shape the pipes by hand with a hammer and a jigsaw. I made a template/jig for the manifold of a piece of wood and shaped everything to fit that. Where did you find the aluminum 180's? Source? Thanks, Andys |
gabeurgelles |
Sep 4 2016, 04:50 PM
So it was time to build an intake manifold. I started by finding some 180 degree bends with the correct radius. After a lot of looking I found what I was looking for and ended up paying around $90 for 5 bends. Since I don't have access to a machine shop, all the fabrication had to take place in my garage with everyday tools. I was able to shape the pipes by hand with a hammer and a jigsaw. I made a template/jig for the manifold of a piece of wood and shaped everything to fit that. Where did you find the aluminum 180's? Source? Thanks, Andys Sharpe Products, they supply aluminum for hand rails and they come in many different radius'. The ones I used were 1.5" OD, 4 inch radius and .125" wall thickness. |
Lo-Fi Version | Time is now: 8th May 2024 - 10:49 PM |
