FS 914 with Chevy 327 |
Emmerich |
Jun 12 2015, 02:27 PM
Newbie Group: Members Posts: 2 Joined: 16-December 10 From: Dallas Member No.: 12,491 Region Association: None |
Fred Emmerich 214-733-6298
Price $25k Chevy 350 block w/327 crank Engine hour meter Accusump lubrication system 911 Front brakes Full roll cage including door bars Custom gauge that has fuel/water temp/oil temp/oil pressure Removable Momo steering wheel Corbeau Forza racing seat (include original) 5 point harness for driver Meziere 55 GPH electric water pump (include new Renegade Hybrids belt driven unit). Pump can be turned on manually to quickly cool down car, radiator fans work off of temperature. Griffin aluminum radiator w/fan Turbo tie rod ends Turbo axles 915 gearbox with ring & pinion swapped and magnetic speedo pickup Corvette headers New Maganaflow mufflers 2 Front mounted oil coolers with fans 916 front fiberglass bumper All wheel wells flared NOS dashboard Mallory ignition Renegade hybrids bell housing adapter Rod Simpson shift adapter to make 914 a tail shifter Koni shock absorbers Rebuilt starter Renegade hybrids nylon adapters for 1 inch inlets to block Insulated firewall (both sides) Fill point tank is Pantera swirl tank Turbo Fuchs (7's and 9's) Edelbrock valve covers. e-mail for more pics, i have plenty but board makes you do one at a time. Could not be duplicated for $50k. Great car, all it needs is cosmetics, prep and paint. The engine bay and trunk and door jambs have already been painted orange. It is a Porsche color from the time the car was made. I think it will look great. Hopefully a 914 guy will want it. It is scary fast, the engine was built to be 400HP but it has not been on a dyno. Attached image(s) |
john914somers |
Nov 22 2015, 09:13 AM
Member Group: Members Posts: 59 Joined: 24-January 12 From: sacramento Member No.: 14,051 Region Association: Northern California |
Are the fender flares steel or fiberglass? Thanks!
Lo-Fi Version | Time is now: 19th May 2024 - 06:29 PM |
