| r_towle |
Jun 12 2015, 04:52 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I went to ln engineering and see the IMS bearing is for up to 2005.
I was under the impression the issue went until 2013? |
| Sprovost |
Jun 12 2015, 05:11 PM
Newbie ![]() Group: Members Posts: 16 Joined: 20-February 13 From: Salt Lake City Member No.: 15,556 Region Association: Rocky Mountains |
For what it's worth, my local Porsche dealer told me that the issue was solved with 2009 & above.
| Cairo94507 |
Jun 12 2015, 05:17 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,657 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I agree. It was resolved when they went to the DFI engines 2009.
| billh1963 |
Jun 12 2015, 05:24 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
| john_g |
Jun 12 2015, 05:26 PM
Member ![]() ![]() Group: Members Posts: 110 Joined: 1-November 12 From: british columbia Member No.: 15,100 Region Association: Canada |
| Jake Raby |
Jun 12 2015, 10:00 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Read IMS 101 here at www.imsretrofit.com
M96 engines used the dual row bearing from 97-2000. The single row from 2001-2005. The M97 engine brought with it an IMS Bearing that was 26% larger and can't be retrofitted with the processes I invented due to the bearing being larger than the crankcase port used to remove it. The M97 used this bearing through 2008. In 2009 the factory gave us the 9a1 engine, with no IMSB, and a host of other issues. 2009 is NOT a magic year, and the future will prove what we've been seeing for 5 years working with the 9a1 engines, some that have failed at only 4,165 miles. The GT3 and Turbo engines utilized the Mezger design IMS/ Layshaft through 2013 when they were also replaced with the 2 chain engine, missing a layshaft for the first time. Attached thumbnail(s) |
| EdwardBlume |
Jun 13 2015, 01:24 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
There goes my plan for an '09. What about 2013-on Boxsters and Caymans dream killer?
| billh1963 |
Jun 13 2015, 05:12 AM
Read IMS 101 here at www.imsretrofit.com M96 engines used the dual row bearing from 97-2000. The single row from 2001-2005. The M97 engine brought with it an IMS Bearing that was 26% larger and can't be retrofitted with the processes I invented due to the bearing being larger than the crankcase port used to remove it. The M97 used this bearing through 2008. In 2009 the factory gave us the 9a1 engine, with no IMSB, and a host of other issues. 2009 is NOT a magic year, and the future will prove what we've been seeing for 5 years working with the 9a1 engines, some that have failed at only 4,165 miles. The GT3 and Turbo engines utilized the Mezger design IMS/ Layshaft through 2013 when they were also replaced with the 2 chain engine, missing a layshaft for the first time. Jake, What issues are 9a1 engines seeing? I thought the elimination of the Intermediate Shaft Bearing and a new rear main seal design solved the biggest issues with the earlier engines? |
| campbellcj |
Jun 13 2015, 12:29 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,712 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
| Jake Raby |
Jun 14 2015, 06:47 AM
Cylinder failures and timing chain failures. There has also been a rash of on- track failures of the oil pump drive sprocket.
Just buy an earlier car and perform an IMS retrofit. |
Lo-Fi Version | Time is now: 4th June 2026 - 02:32 AM |
