Oil Leak, Is my mechanic right? |
dmilzoff |
Jun 6 2003, 05:12 PM
Member Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 |
I have a 914-6 with a 3.0. It has been used 1-200 miles per year for the past 4 years and has had moderate oil drips. I accepted the drips in my garage since I only used 1 quart of oil each year. I want to track the car now and I just had major work ($$$) done including changing oil from 50 weight to 10-30 Mobil 1. Now I have more leaks than ever - the car used 2 quarts of oil during 1 day of AutoX. I cannot see any oil leaking. My mechanic says it may be oil leaking past the valve guides into the combusiton chambers - meaning major overhaul and major cost.
Would returning to a higher weight oil (synthetic) help or is the overhaul necessary? Suggestions? Help!!!! |
Lawrence |
Jun 6 2003, 06:10 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
Changing back to a different oil is a cheaper test than pulling the heads.
A leakdown and/or compression test might tell you if you have issues with rings. -Rusty |
Lo-Fi Version | Time is now: 19th May 2024 - 04:17 AM |
