big step, oil tank is welded |
worn |
Jun 16 2015, 01:13 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
For my 3.2 I have made several parts myself from scratch. The engine tin, many other buyable pieces, but the one I was after has been the oil tank. For those of you who know how to tig, you can just start laughing at how easy this is and come back later. For me though, I knew how to make shapes in sheet metal, and how to weld steel, but aluminum was a new frontier. Dabbled in trying to weld with gas, and I still hope to learn. Then bought a TIG, figuring it cost a bit more than half of a complete tank with all the parts. Used a blow up of the blueprint from the factory originally from a file posted by SLITS.
But having done all the work what scared me was the prospect of the thing slumping into a pile of slag at the end. Well, oddly, I got better, not good, but better at tig welding. So it is welded up, complete with 911 filler and dipstick, and AN fittings for everything else. I now know I could have done the filter console, but I am kind glad I didn't try. Oil goes in at the original location where the pipe came from the filter at the top of the tank. There is a stainless steel screen for baffling. I am using 3 hard points with 8 mm time serts and studs for fastening. Goes into place in seconds. Of course the metal finishing isn't done. And it has to be leak tested and though clean as a whistle when I put the clams together, I will send a camera in to double check and then wash it. More later, cause I have to go. This was the big stall in getting the engine in and started. So: (IMG:style_emoticons/default/piratenanner.gif) |
Valy |
Jun 16 2015, 02:51 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Lo-Fi Version | Time is now: 18th May 2024 - 01:44 AM |
