SoCal shop to sort out my shifter, new problem, transmission leaks |
john77 |
Jun 19 2015, 03:47 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Shifting into first has started making a blood curdling grinding noise even when I come to a dead stop. My shifter is sloppy as hell - I dread any AX course where I get into 3rd as more often than not I'll downshift into 4th rather than 2nd - so I'd been considering upgrading, possibly to a Rennshift, for a while anyway. So, I'm thinking it might be time for a whole gearbox/shifter/bushing 'while I'm in there' upgrade.
Anyone in SoCal had this done and been really pleased with the results? Any shop in SoCal you could recommend? I know it's rarer than an albino saquatch, but I'd love to come out the other side of this with as precise a 914 gear change as possible. |
Heeltoe914 |
Jun 21 2015, 10:33 AM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Its really easy to do it yourself bring a pin an paper I will show over Lunch. You buy (IMG:style_emoticons/default/smile.gif)
If you happen to order all the bushing before coming out I can show you how easy it is on the lift. PM me here |
john77 |
Jun 22 2015, 04:09 PM
Its really easy to do it yourself bring a pin an paper I will show over Lunch. You buy (IMG:style_emoticons/default/smile.gif) If you happen to order all the bushing before coming out I can show you how easy it is on the lift. PM me here Thanks so much, what a generous offer. I'll shoot you a PM. It only got worse yesterday after AX. It was hard to get into first/reverse all day (nothing new), but then on the way home it suddenly started getting harder and harder to get into any gear (IMG:style_emoticons/default/unsure.gif) Hopefully, that points toward the problem being with the shift linkage/bushings rather than the transmission. |
Lo-Fi Version | Time is now: 15th May 2024 - 10:42 AM |
