SoCal shop to sort out my shifter, new problem, transmission leaks |
john77 |
Jun 19 2015, 03:47 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Shifting into first has started making a blood curdling grinding noise even when I come to a dead stop. My shifter is sloppy as hell - I dread any AX course where I get into 3rd as more often than not I'll downshift into 4th rather than 2nd - so I'd been considering upgrading, possibly to a Rennshift, for a while anyway. So, I'm thinking it might be time for a whole gearbox/shifter/bushing 'while I'm in there' upgrade.
Anyone in SoCal had this done and been really pleased with the results? Any shop in SoCal you could recommend? I know it's rarer than an albino saquatch, but I'd love to come out the other side of this with as precise a 914 gear change as possible. |
john77 |
Jun 29 2015, 10:16 PM
Managed to finally get under the car tonight. It's a 73, but the number on the tranny case is 914.301.101.00, which unless Google is lying is a tail-shifter, so I just wanted to check what I'm dealing with. Is this tail-shifter or a tail-shifter that's been converted to a side shifter?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1435637812.1.jpg) Question 2: Do I just tighten the the nut at the end of the clutch cable to adjust the clutch? And, finally, there seems to be a bar blocking me from getting a wrench in to remove the top plug in the transmission. Is that normal, or is what I'm looking at not the top drain plug? (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1435637812.2.jpg) |
Lo-Fi Version | Time is now: 15th May 2024 - 11:59 AM |
