SoCal shop to sort out my shifter, new problem, transmission leaks |
john77 |
Jun 19 2015, 03:47 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Shifting into first has started making a blood curdling grinding noise even when I come to a dead stop. My shifter is sloppy as hell - I dread any AX course where I get into 3rd as more often than not I'll downshift into 4th rather than 2nd - so I'd been considering upgrading, possibly to a Rennshift, for a while anyway. So, I'm thinking it might be time for a whole gearbox/shifter/bushing 'while I'm in there' upgrade.
Anyone in SoCal had this done and been really pleased with the results? Any shop in SoCal you could recommend? I know it's rarer than an albino saquatch, but I'd love to come out the other side of this with as precise a 914 gear change as possible. |
Bob L. |
Jun 30 2015, 11:05 AM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Something funky there...
I don't have a bar like that on mine. Or any of those brackets/links connected to it. one looks like a dipstick tube. I would inspect those bits and see if they do anything. Someone here will probably know what they are from/for. That is the fill plug half blocked by the top of the bar. I think the drain plug is under the bar just behind the clutch cable pulley. Always make sure you can get the fill plug open before you drain it. |
Hank914 |
Jun 30 2015, 11:07 AM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
Something funky there... I don't have a bar like that on mine. Or any of those brackets/links connected to it. one looks like a dipstick tube. I would inspect those bits and see if they do anything. Someone here will probably know what they are from/for. That is the fill plug half blocked by the top of the bar. I think the drain plug is under the bar just behind the clutch cable pulley. Always make sure you can get the fill plug open before you drain it. (IMG:style_emoticons/default/agree.gif) Plus looks to me that you do have a side shift not a tail shift. |
Lo-Fi Version | Time is now: 14th May 2024 - 07:16 PM |
