SoCal shop to sort out my shifter, new problem, transmission leaks |
john77 |
Jun 19 2015, 03:47 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Shifting into first has started making a blood curdling grinding noise even when I come to a dead stop. My shifter is sloppy as hell - I dread any AX course where I get into 3rd as more often than not I'll downshift into 4th rather than 2nd - so I'd been considering upgrading, possibly to a Rennshift, for a while anyway. So, I'm thinking it might be time for a whole gearbox/shifter/bushing 'while I'm in there' upgrade.
Anyone in SoCal had this done and been really pleased with the results? Any shop in SoCal you could recommend? I know it's rarer than an albino saquatch, but I'd love to come out the other side of this with as precise a 914 gear change as possible. |
john77 |
Jul 1 2015, 10:56 AM
Which bushings are we talking about? (IMG:style_emoticons/default/smile.gif) The car was built in 2008, but didn't see that much action until I bought it 18 months ago. The more I poke around under it it seems like pretty much every single bushing on it needs replacing.
Seriously though, do you mean the shift linkage bushings or the tranny mount bushings? |
ChrisFoley |
Jul 1 2015, 11:21 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Which bushings are we talking about? (IMG:style_emoticons/default/smile.gif) The car was built in 2008, but didn't see that much action until I bought it 18 months ago. The more I poke around under it it seems like pretty much every single bushing on it needs replacing. Seriously though, do you mean the shift linkage bushings or the tranny mount bushings? I'm pretty sure he meant the shift bushings since that's the main topic. You should check the tranny mounts too though. Sometimes the rubber is badly age cracked, but at least the design won't allow the assembly to fall apart if the rubber does fail. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:35 AM |
