SoCal shop to sort out my shifter, new problem, transmission leaks |
john77 |
Jun 19 2015, 03:47 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Shifting into first has started making a blood curdling grinding noise even when I come to a dead stop. My shifter is sloppy as hell - I dread any AX course where I get into 3rd as more often than not I'll downshift into 4th rather than 2nd - so I'd been considering upgrading, possibly to a Rennshift, for a while anyway. So, I'm thinking it might be time for a whole gearbox/shifter/bushing 'while I'm in there' upgrade.
Anyone in SoCal had this done and been really pleased with the results? Any shop in SoCal you could recommend? I know it's rarer than an albino saquatch, but I'd love to come out the other side of this with as precise a 914 gear change as possible. |
Steve |
Jul 1 2015, 11:38 AM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
On top of checking the bushings, check the shift coupler. It's at the firewall under the rubber cover. There are two bushings in the coupler that turn to plastic over the years and disintegrate.
ChrisFoley |
Jul 1 2015, 01:05 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
On top of checking the bushings, check the shift coupler. It's at the firewall under the rubber cover. There are two bushings in the coupler that turn to plastic over the years and disintegrate. He'll be replacing that coupler with a u-joint in a week or so. Thanks for the order John! (IMG:style_emoticons/default/smile.gif) |
john77 |
Jul 1 2015, 01:19 PM
On top of checking the bushings, check the shift coupler. It's at the firewall under the rubber cover. There are two bushings in the coupler that turn to plastic over the years and disintegrate. He'll be replacing that coupler with a u-joint in a week or so. Thanks for the order John! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 04:39 AM |
