SoCal shop to sort out my shifter, new problem, transmission leaks |
ChrisFoley |
Jul 1 2015, 11:21 AM
I am Tangerine Racing Group: Members Posts: 7,911 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Which bushings are we talking about? (IMG:style_emoticons/default/smile.gif) The car was built in 2008, but didn't see that much action until I bought it 18 months ago. The more I poke around under it it seems like pretty much every single bushing on it needs replacing. Seriously though, do you mean the shift linkage bushings or the tranny mount bushings? I'm pretty sure he meant the shift bushings since that's the main topic. You should check the tranny mounts too though. Sometimes the rubber is badly age cracked, but at least the design won't allow the assembly to fall apart if the rubber does fail. |
Steve |
Jul 1 2015, 11:38 AM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
On top of checking the bushings, check the shift coupler. It's at the firewall under the rubber cover. There are two bushings in the coupler that turn to plastic over the years and disintegrate.
ChrisFoley |
Jul 1 2015, 01:05 PM
On top of checking the bushings, check the shift coupler. It's at the firewall under the rubber cover. There are two bushings in the coupler that turn to plastic over the years and disintegrate. He'll be replacing that coupler with a u-joint in a week or so. Thanks for the order John! (IMG:style_emoticons/default/smile.gif) |
Steve |
Jul 1 2015, 01:10 PM
On top of checking the bushings, check the shift coupler. It's at the firewall under the rubber cover. There are two bushings in the coupler that turn to plastic over the years and disintegrate. He'll be replacing that coupler with a u-joint in a week or so. Thanks for the order John! (IMG:style_emoticons/default/smile.gif) Nice!!!! Love your products Chris!! Your 915/916 adapter works great and saved me tons of time with adjustments. |
john77 |
Jul 1 2015, 01:19 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
On top of checking the bushings, check the shift coupler. It's at the firewall under the rubber cover. There are two bushings in the coupler that turn to plastic over the years and disintegrate. He'll be replacing that coupler with a u-joint in a week or so. Thanks for the order John! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) |
Chris Pincetich |
Jul 1 2015, 01:34 PM
The Rennshifter is great, but stiff. Best as the "last" upgrade. Worth it! (IMG:style_emoticons/default/beerchug.gif)
After I replaced shift rod bushings, I fixed lots more slop by changing the transaxle mount bushings. They were cracked and almost falling apart, and you couldn't see the cracked rubber until you had them off and in your hand. WEVO makes a nice upgrade (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/driving.gif) |
john77 |
Jul 1 2015, 03:10 PM
The Rennshifter is great, but stiff. Best as the "last" upgrade. Worth it! (IMG:style_emoticons/default/beerchug.gif) After I replaced shift rod bushings, I fixed lots more slop by changing the transaxle mount bushings. They were cracked and almost falling apart, and you couldn't see the cracked rubber until you had them off and in your hand. WEVO makes a nice upgrade (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/driving.gif) Thanks Chris. I just finished reading the tech article on the bird about this and from the symptoms it does sound like my tranny mounts, and possibly also my engine mounts, could do with replacing. Not really confident this is a job I can do myself though. |
campbellcj |
Jul 2 2015, 06:58 PM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Thanks Chris. I just finished reading the tech article on the bird about this and from the symptoms it does sound like my tranny mounts, and possibly also my engine mounts, could do with replacing. Not really confident this is a job I can do myself though. Trans mounts are a very easy DIY. Engine mounts are not quite as quick/easy but also totally DIY-able. Same with the Rennshifter which is a very nice upgrade once everything else is sorted out properly. The damn linkage bushings might be the most frustrating bits truthfully. And you definitely should check/replace your clutch cable "while you're in there" and that is also one of the least-fun jobs on a 914 but again, DIY-able without much wrenching experience. |
john77 |
Jul 2 2015, 10:27 PM
[/quote]
Trans mounts are a very easy DIY. Engine mounts are not quite as quick/easy but also totally DIY-able. Same with the Rennshifter which is a very nice upgrade once everything else is sorted out properly. The damn linkage bushings might be the most frustrating bits truthfully. And you definitely should check/replace your clutch cable "while you're in there" and that is also one of the least-fun jobs on a 914 but again, DIY-able without much wrenching experience. [/quote] I tightened and 'double-nutted' the clutch cable today. Immediately helped the shifting, and reverse stopped grinding, but first is still doing it if I try to shift into it too quickly. I changed the tranny oil too and put in new Swepco 201. No idea how long it had been in there, but it had a really funny smell, looked like engine oil, and had a goldish foam on top of it. As soon as they come I'll be swapping out the mounts and fitting the new linkage and firewall bushing. |
0396 |
Jul 3 2015, 03:34 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Its best to learn the basics on your shifter questions. If you had to take car in for every little concerned.
This 914 owner ship will turn upside-down really quick. Labor rate for a 914 is the same as a 991. Good luck |
rhodyguy |
Jul 3 2015, 03:04 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Try putting the trans into 2nd before 1st. Just like in an old beetle.
john77 |
Jul 8 2015, 09:31 PM
Changed my transmission mounts over the weekend - it was as simple as everyone said. Really surprised how much it tightened up my shifter. I also changed the tranny oil. The old oil smelled very odd, who knows the last time it was changed.
My transmission was leaking pretty badly before I changed the oil, but now I have I can see blue traces from the new oil. The two main places seem to be where the side shifter arm enters the case and this part in the picture. What is this? It moves a lot if I grab it. Is there a way to stop these leaks without taking the transmission apart? (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1436412702.1.jpg) |
Harpo |
Jul 9 2015, 03:59 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
The part with 90 degree bend closest to the lens is the speedo cable. This is a notorious place for the 901 trans to leak. McMark and Possibly 914 rubber makes a new/improved part with a second "O" ring that works great.
David |
john77 |
Jul 9 2015, 01:46 PM
Lo-Fi Version | Time is now: 28th April 2024 - 09:36 PM |
