> Oil pressure jumped, Oil pressure up next day after hot drive
lugnuts
post Jun 20 2015, 08:00 AM
I'm a newbie so be patient.
I just purchased 74 2.0 and drove it home 100+ miles on 98 degree day. Temp gauge got in the 260-280 range but I "made it".
Couple days after, I cranked the car to put it on the lift for a once over and prep for oil change.
After cranking oil pressure reads 80+ and light is on. NO unusual noise. Idles ok
Once I saw pressure was hanging out in the high zone and the light was on I immediately turned it off.
What have I done? (IMG:style_emoticons/default/headbang.gif) What steps to analyze the issue?
FYI,
Once on lift I did find the wire from thermostat was not connected (Per reading, I believe it fails to desired flap position for cooling)
Per PO receipt for most recent oil change using Castrol 20-50 @ 4.8 qts
Replies(1 - 2)
rhodyguy
post Jun 20 2015, 08:33 AM
essentially, 5 quarts is a lot of oil! recheck the oil level in the car while cold and static.
Java2570
post Jun 20 2015, 08:38 AM
Oil change with filter replacement should get 3.7 quarts....you're overfilled! Definitely check that level out and replace with a high zinc oil like Joe Gibbs Driven, Brad Penn, or Valvoline VR1. Also, check integrity of oil pressure and temp senders, wires, etc.
Not a bad idea to plumb in manual gauges to check out pressure and compare to what your cockpit gauge says....
- Lo-Fi Version Time is now: 1st May 2026 - 01:36 PM
