| last337 |
Jun 21 2015, 09:42 AM
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
Just a question about alternator. Does the one lead just go straight to the positive post on the battery? Is the regulator built into the alternator?
| Dtjaden |
Jun 21 2015, 10:21 AM
Member ![]() ![]() Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
The d+ lead goes to the starter and then to the battery +. The regulator is on the relay board. The above assumes that a previous owner has not made changes.
| last337 |
Jun 21 2015, 10:53 AM
The d+ lead goes to the starter and then to the battery +. The regulator is on the relay board. The above assumes that a previous owner has not made changes. Okay well I had that right then I think. The ring goes to main post on starter and then from there to + on battery. The only other connection I have on starter is yellow lead. Am I missing anything else? |
| last337 |
Jun 21 2015, 11:27 AM
The d+ lead goes to the starter and then to the battery +. The regulator is on the relay board. The above assumes that a previous owner has not made changes. Okay well I had that right then I think. The ring goes to main post on starter and then from there to + on battery. The only other connection I have on starter is yellow lead. Am I missing anything else? Still nothing. Not even getting power to fuel pump with key on and nothing when I go to start. What else hooks to starter besides alternator lead and yellow wire? |
| 76-914 |
Jun 21 2015, 11:36 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,965 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Bat + lead
Lo-Fi Version | Time is now: 21st September 2026 - 12:55 AM |
