Instructions for 914 hand throttle, Anybody has a set |
PanelBilly |
Jun 21 2015, 01:36 PM
914 Guru Group: Members Posts: 5,797 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Left a message at the 914 rubber site a while back, but I'm guessing Mark is busy. I'm like to install the hand throttle I got but don't know what happen to the instructions.
914Sixer |
Jun 21 2015, 01:59 PM
914 Guru Group: Members Posts: 8,868 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Try looking at the PET. The exploded diagram should give you an idea how it goes together.
t collins |
Jun 21 2015, 02:38 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
PM sent
jim_hoyland |
Jun 21 2015, 03:41 PM
Get that VIN ? Group: Members Posts: 9,258 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Left a message at the 914 rubber site a while back, but I'm guessing Mark is busy. I'm like to install the hand throttle I got but don't know what happen to the instructions. How about posting the steps you do for the install ? There were some pictures posted, but it didn't make a lot of sense to me. And, I have the manual throttle and would like to get it installed. (IMG:style_emoticons/default/smile.gif) |
mm911 |
Jun 21 2015, 04:39 PM
Newbie Group: Members Posts: 8 Joined: 18-January 13 From: martin tennessee Member No.: 15,385 Region Association: None |
Left a message at the 914 rubber site a while back, but I'm guessing Mark is busy. I'm like to install the hand throttle I got but don't know what happen to the instructions. I had the same question and installation with a center console. Look at the "Member Vendors" section and scroll down to "Mickey's open group buys" (914 rubber) then scroll down to "Hand throttle for carbd......" A lot of useful information on installation and my question about the center console. Hope this helps. |
PanelBilly |
Jun 21 2015, 04:52 PM
Thanks, but I'm going to get the engine running before I pull the pedal cluster out again.
Harpo |
May 3 2016, 05:49 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I just purchased Marks hand throttle. Can someone please post some instructions? PanelBilly?
Thanks David |
gms |
May 3 2016, 06:39 PM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
does this help?
PanelBilly |
May 3 2016, 07:16 PM
I still haven't installed mine and I don't know if I ever will. The carbs like a few pumps before I turn the key but if I give it throttle after, it dies. If I leave it alone until it warms up a little it fine.
Mikey914 |
May 4 2016, 12:11 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Really just need to get one installed so that I can get some pictures. I'll see if Cary may be able to get one into my blue car. If we can get some pics it will help.
Mark |
Jonathan Livesay |
May 4 2016, 01:33 PM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Really just need to get one installed so that I can get some pictures. I'll see if Cary may be able to get one into my blue car. If we can get some pics it will help. Mark (IMG:http://www.914world.com/bbs2/uploads_offsite/i65.tinypic.com-11461-1462390401.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i68.tinypic.com-11461-1462390401.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i66.tinypic.com-11461-1462390401.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i67.tinypic.com-11461-1462390402.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i65.tinypic.com-11461-1462390402.5.jpg) Once it's installed there is not too much to see. It works great, or did until I got completely annoyed by the racket from the loose rear window and decided to take it out and reseal it. Then decided to clean up the loose and torn vinyl on the roll bar then the flaking paint and surface rust around that, then what the hell might as well get it all ready for paint and paint it. But the hand throttle is nice. (IMG:style_emoticons/default/biggrin.gif) You can see the lever, the head of the bolt than holds the rod guide in the tunnel, and the plate that has to be mounted on the accelerator linkage. And that's about all. |
porschetub |
May 4 2016, 01:58 PM
Left a message at the 914 rubber site a while back, but I'm guessing Mark is busy. I'm like to install the hand throttle I got but don't know what happen to the instructions. I had the same question and installation with a center console. Look at the "Member Vendors" section and scroll down to "Mickey's open group buys" (914 rubber) then scroll down to "Hand throttle for carbd......" A lot of useful information on installation and my question about the center console. Hope this helps. That's where I got my info now I remember,I built one out of parts in my shed after buying a spare heater lever. Hardest part was welding the plate on the throttle lever,when you build it you know where it all goes (IMG:style_emoticons/default/smile.gif) |
SA-914 |
May 4 2016, 07:40 PM
Member Group: Members Posts: 125 Joined: 30-June 14 From: San Antonio,tx Member No.: 17,566 Region Association: Southwest Region |
This is what I used. http://www.914world.com/bbs2/index.php?act...t&id=333490
Larmo63 |
May 28 2016, 05:59 PM
Does anybody have an extra lever and black knob for this throttle set-up?
wndsnd |
May 28 2016, 07:16 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Tangerine can make you a nice set up.
I was intimate with my tunnel today while installing a new throttle cable and checking the welds on the clutch tube. Chris and Ed did mine and it is their typical high quality installation. |
jim_hoyland |
May 28 2016, 09:11 PM
Fits the stock shifter plate fine; renshifters need a slit cut in the front to accommodate the lever.... (IMG:style_emoticons/default/smile.gif)
forrestkhaag |
May 29 2016, 09:31 AM
And while you have the throttle bell rank out of the pedal cluster getting the tab welded on to it, consider replacing with the bronze bushings at reinstall.
(IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
Lo-Fi Version | Time is now: 23rd April 2024 - 11:49 PM |
