Quaife?, Where the best prices are? |
ArtechnikA |
Feb 25 2005, 11:02 AM
you are correct in that with a torque-biasing diff, when a wheel has ZERO grip, it will spin; in this reqime, it acts just like an open diff. similarly, the torque-biasing diff works only under drive - not overrun (braking. |
brant |
Feb 25 2005, 01:53 PM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Ken, my comment about "how much pressure" was aimed specifically at the comment about a TB not functioning when a wheel was lifted. To rephrase, I was asking if a TB would work when say a wheel is unweighted some, but still had 100lbs.. (or 200lbs, or x lbs) of weight on it. each of us has to make our own decisions and findings. I usually take advice from my the local guru who has been giving me good advice for 15years. my guy, AJ installed my locked diff (not really a spool, just a welded diff) and has never given me bad advice. I believe that the HP threshold is based somewhat on smoothness. I'm theorizing here, but would guess he was trying to explain to me that a high HP car can still be faster on a track by improving traction and giving up smoothness... Where a lower HP application is faster on the track by highlighting the smoothness from a TB diff and has limited gains in traction due to the ability of a race tire in a dry situation to put down a good amount of torque. So What I was asking is in reference to the comment that "a TB diff does not work when one wheel is unloaded" do you know if that is true only when fully unloaded or still true if just partially unloaded? I trust my guy and will put together next years box with a TB, but still love to learn. |
brant |
Feb 25 2005, 02:15 PM
Rich, thanks for your time, and thanks for writting all of this out! I was very clearly told when I went with the locked diff that I would: a) need to re-learn the driving and (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) reminded that in (low traction) rain or sand, things would get scarry fast. I had to re-learn to deal with the understeer. Kinda like the 911 guys have Known for years. Its truly a "dirt-track" style to get the car to rotate. You literally force the rear into a slide until you are pointing the direction you want, and then apply power to go straight. for that reason, I'm guessing that the whole differential debate is based upon some cars/some levels of HP/and some driving styles are better off with one type over the other. I think that you can still be smooth with a locked diff/spool, but its a whole different type of smooth which involves constant "smooth" drifting and dancing on the traction limit. |
KenH |
Feb 25 2005, 03:46 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
http://www.quaifeamerica.com/
They should be able to answer questions about the TB's operating range. The understeer was not that great on mine. 2223# car, 225# rear springs, stock rear swaybar, 22mm front torsion bars, 22mm front sway bar set 1-1/2". Still "tweeking". Ken |
brant |
Feb 25 2005, 05:01 PM
I've been told, that the understeer is not bad with the TB...
Its good that you confirm that. Its on the locked diffs that the understeer is significant. The rear remains locked at all times (like an 80%ZF except more so) I anticipate that a TB diff will let me go back to a much smoother and less "dirt track-ish" driving style... Thus the exact reason the TB is supposed to be smoother and possibly quicker (according to some) I've made up my mind long ago.. my wallet just won't let me play yet. |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:09 PM |
