Brake master cylinder woes |
jmargush |
Jun 22 2015, 08:30 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I put a new 19mm master cylinder from PMB on my car within the last two years.
The pedal had been getting a little more travel in it over the past week or two. Yesterday at the Autox the pedal got enough travel that it tripped the warning light on. Does this point to a failed master cylinder? If I pump the pedal it will build pressure and reduce travel. after this is done it doesn't seem to drift to the floor with continued pressure. I bought from PMB because I learned form Eric that the ones you by at FLAPS don't have the correct material in the seals and that a new one should last years. |
jmargush |
Jun 26 2015, 06:40 PM
Starting the process of trying to find where the brake system might be drawing air in.
If the bleed screws on the calipers were leaking wouldn't they be pushing fluid out or am I not thinking about this correctly? |
76-914 |
Jun 26 2015, 06:54 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Lo-Fi Version | Time is now: 19th May 2024 - 04:01 AM |
