Brake master cylinder woes |
jmargush |
Jun 22 2015, 08:30 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I put a new 19mm master cylinder from PMB on my car within the last two years.
The pedal had been getting a little more travel in it over the past week or two. Yesterday at the Autox the pedal got enough travel that it tripped the warning light on. Does this point to a failed master cylinder? If I pump the pedal it will build pressure and reduce travel. after this is done it doesn't seem to drift to the floor with continued pressure. I bought from PMB because I learned form Eric that the ones you by at FLAPS don't have the correct material in the seals and that a new one should last years. |
jmargush |
Jun 30 2015, 12:44 PM
All the calipers were rebuilt about 12 yrs ago
I'll have to get back in the car and see exactly what the pedal is doing after pumping I'll also run through rear brake adjustment procedure again |
Lo-Fi Version | Time is now: 19th May 2024 - 03:47 AM |
