| dudzy's914 |
Jun 23 2015, 08:58 AM
The youngin' ![]() ![]() Group: Members Posts: 271 Joined: 21-December 13 From: Hatfield, MA Member No.: 16,784 Region Association: North East States |
So my door catch is stuck closed. The door is not latched to the car, the door is open, the latch just won't move. It feels that it is locked but I have the lock lever open. any tips to fixing it would be greatly appreciated.
-Finn |
| Hank914 |
Jun 23 2015, 10:37 AM
Member ![]() ![]() Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
I have a similar situation. I can open from the inside handle but not from the outside handle. I'll be following this hot read with interest.... |
| Larmo63 |
Jun 23 2015, 10:44 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
You have to take the door handle and inner door mechanism out of the car's door and clean it. Soak it in some sort of cleaner for a while, wipe, brush, and re-lubricate.
You'll be amazed how good they can actually work when clean. |
| Bob L. |
Jun 23 2015, 01:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
(IMG:style_emoticons/default/popcorn[1].gif) I have a similar situation. I can open from the inside handle but not from the outside handle. I'll be following this hot read with interest.... You probably need to replace the plastic piece in the door handle that pushes the latch lever. They're cheap and pretty easy to do. http://shop.914rubber.com/door-cam-actuato...m?categoryId=-1 |
Lo-Fi Version | Time is now: 14th April 2026 - 05:59 PM |
