brake caliper identification help, bitte., 911 stuff, but what years? |
Chris914n6 |
Jun 24 2015, 09:31 PM
Jackstands are my life. Group: Members Posts: 3,321 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Need help figuring out what years these came from so I can rebuild them. All ATE, all 3"
#1 Measured 42mm but I think its 48 behind the seal. Disc gap 24mm. M front? (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1435203080.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1435203080.2.jpg) set2- Pretty sure it's 38mm. Disc gap 14mm. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1435203080.3.jpg) set3- Pretty sure it's 38mm. Disc gap 24mm. Small diameter at pad contact, 27mm. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1435203080.4.jpg) set4- Pretty sure it's 38mm. Disc gap 24mm. 34mm at pad contact. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1435203080.5.jpg) |
davep |
Jun 25 2015, 04:16 AM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Yes, I think that you are correct: 911 parts. The rears are definitely 911/late 912 non-vented. Fronts are for vented rotor, and probably came from the same car.
Chris914n6 |
Jul 26 2015, 06:05 PM
Updated. Still could use some assistance.
Eric_Shea |
Jul 27 2015, 05:29 PM
You have M-Caliper Fronts and M-Caliper Rears
Basically 1970-1974ish 911T Calipers 48mm Front Pistons 38mm Rear Pistons All with knock-back mechanisms. Pretty common stuff. We have all the kits in stock. |
Lo-Fi Version | Time is now: 21st May 2024 - 12:00 PM |
